Results 1 to 14 of 14
    7,189
    Default Loan of a Steel hoop or piece of steel with a hole about 350 mm in diameter
    I have a 400 mm diameter x 4 mm thick Al plate in which a 200 mm diameter hole will be cut out of the middle (LHS in pc) and would like to make it slightly dished/conical shaped with a press and some heat. Basically I want it to look like ether blue one but without teh collar.
    I have a strong steel pulley that is 250 mm in diameter and now need a loan of a ~350 mm steel hoop or piece of steel with a hole about 350 mm in diameter to act as a temporary die/base. The amount of dishing from outer edge to edge of the inner hole needs to be about 20 mm. I have no idea if this will work or not.
    I was going to use wood for the 350 mm hoop but given that heating with a propane will be involved then wood is out
    Can anyone local loan me a hoop or a piece of steel with a ~350 mm hole in it? If not then I will make one out of some strap.
    Oct 2004
    Southern Highlands NSW
    1,898
    I've no experience, but from what I've seen and read about, you might more easily get what you want by hydroforming.
    No die might be needed, but if accuracy is important a die could be used I think.
    7,189
    Quote Originally Posted by nadroj View Post
    Thanks for the info No accuracy needed - I just want to slightly conicalize (is there such a word) the Al plate
    Dec 2013
    Sydney
    201
    Can you use the pulley as a mandrel in a lathe to spin the aluminium plate to shape?
    Graham.
    May 2011
    Murray Bridge S Aust.
    5,959
    Hi Bob, have you thought about using a car rim?? Possibly something like a 13 inch wheel might be close for what is required or a rim off a Mini?
    Hope this helps,
    7,189
    Quote Originally Posted by Oldbikerider View Post
    Graham.
    Good idea and I also thought of that but a couple of problems with spinning are;
    The swing on my lathe is only 9" and this disc is 390 mm in diam.
    I've tried spinning 1 mm thick, 290 mm diameter Al plates on my and can just do that so theres no way I could do 4mm.
    I went to the mens shed to look for something and on their scrap pile they had a 200 mm long section of 20mm thick steel pipe that was 20 mm too big!
    Could be handy so its going to live at my place for a while.
    Anyway I have bent and welded up a MS hoop from some 25 x 5mm thick flat bar I picked up doing council verge collections - I like it when these little side projects cost naught.
    May 2011
    5,959
    Hydroforming, while a good idea, is practically impossible without a high pressure pump, I doubt a karcher will do it.
    Sep 2008
    Riddells Creek, Vic.
    838
    Unless you can restrain the outer flange with some sort of pressure ring as well you will not get good results.
    May 2011
    5,959
    Jordan, I don't have any experience either with hydro forming, just going by what I've read and seen on You Tube type clips. It takes a lot of pressure to do such items. Saw a clip of hydroforming tube/pipe for Harley frames and was several thousand PSI to correct the freeform flow of the tubes.
    7,189
    Quote Originally Posted by Techo1 View Post
    Thanks for that - I was going to cut up 12, 25mm thick 32 mm diameter steel spacers and G-clamp these outside the hoop between the the plate being bent, and a 12mm thick base plate. at about the position of the dozen holes around the outside.
    Something like this (no spacers shown here) and maybe with some bits of angle between adjacent clamps?
    I will anneal the plate before I try to bend it.
    Feb 2013
    Laidley, SE Qld
    1,039
    I think the edge restraint also needs to have a substantial steel ring beneath the G clamps, I could see the clamps moving and puckering occurring between the clamps if they were the sole edge restraint.
    7,189
    Quote Originally Posted by bob ward View Post
    I agree and was thinking of putting pieces of 5 mm thick angle under the clamps as it does not matter if the start of the outside bend eventuates in a 12 sided bend.
    7,189
    Well I stuffed up along the way but I made something that will be good enough for what I want it to do.
    Setup 1 shows 32 mm hoop and 32mm spacers
    Setup 2 with the clamps and angle pressure plates in place.
    Top view
    Nothing happened till it got to about 5 tons and then I thought it was going crooked but it sort of straightened itself.
    Then at 8 tons a cheap Chinese clamp holding down the outer rim down shattered so I called it quits, as by then it looked like I had enough dishing
    The final dish is doming to 25 mm at the inner lip which is what I was hoping for.
    Here you can see I cut the hole in the Al section a tad too large but I JUST had enough overhang to the use 4mm CS screws to attach the PVC bell mouth hood.
    Underside -
    So now its a "mega bell mouth hood" - I'm happy enough with the final result
    It would have been MUCH easier if I had use 3mm Al and cut teh hole the right size - or maybe not as less hole means less to bend?.
    Dec 2013
    Sydney
    201
    And the flat belt pulley lives to see another day. Good news all around!
    Graham.
  1. mild steel to stainless steel
    By cava in forum WELDING
    Last Post: 27th Nov 2014, 06:48 AM
  2. stainless steel piece
    By hughie in forum THE FOUNDRY
    Last Post: 17th Aug 2014, 10:02 AM
  3. Replies: 3
    Last Post: 25th Jun 2014, 12:44 PM
  4. Drilling a hole in high speed steel
    By Tiger in forum METALWORK GENERAL
    Last Post: 8th Nov 2009, 09:13 AM
  5. Making a 30 mm hole in 1.5mm mild steel
    By jmk89 in forum METALWORK GENERAL
    Last Post: 17th May 2007, 09:59 PM
