Results 1 to 12 of 12
    Oct 2011
    Sydney, NSW
    1,249
    Default Herless SM1 or VM1
    Hi,
    Noticed this one on gumtree awhile ago.
    https://www.gumtree.com.au/s-ad/chel...m-1/1180992036
    Looks a bit worn and too far away but its what I'm looking for. It's the right size for me (weight, height etc) with enough capability.
    Does anyone still sell them new? Or do I need to keep looking out a for a good second hand one?
    Ben
    Dec 2013
    56
    1,416
    https://www.machineryhouse.com.au/M121
    It just looks like the round column mill, square column is a lot better and not that much more expensive.
    Using Tapatalk
    Jun 2007
    Vic
    48
    544
    I don't think the one from Ben link is the same as the round Column. That is more of the Knee mill and the head can tilt too?
    Mar 2008
    nowra
    1,598
    Andre
    Dec 2013
    56
    1,416
    Quote Originally Posted by jackaroo View Post
    True my mistake, I have a hard and Forbes catalog with that same mill from back in the 80s
    Using Tapatalk
    Dec 2013
    56
    1,416
    Here it is with all it's specs, doesn't look they have gone up in price much looking at the link from Andre
    Using Tapatalk
    Aug 2015
    Melbourne, Australia
    843
    They're a good machine. I have an early 90's 8" x 30" SM-1. It is my first mill. It is Thai made - I checked with some old timers at H&F who were there in the Herless days.
    I did a complete nut-and-bolt-and-bearing on mine after rescuing it from near death on a farm near Echuca. It will be going up for sale in a few months when I get the Bridgeport humming. Someone has already expressed an interest in it, but depending on how that goes I can contact you if you like.
    PM me if you want more info on what they are like as a machine. Warts and all.
    Greg.
    Feb 2012
    Willunga
    114
    I think that both of the machines are good buys, small turret mills are hard to get. I just drove 800Km and paid about $1000 off new price for a LW-VHO-A, bottom left on the catalogue. I can actually get it into the shed and it will do most of what I want.
    There is a company in Brisbane who list something like the V0-AIS but they are a number that starts with a 7.
    Ian
    Apr 2021
    Adelaide
    49
    1
    Default Long shot
    Quote Originally Posted by StrayAlien View Post
    Greg.
    Hi Greg this is going to be a long shot, seeing as it was a while ago the last post was put up but here goes.
    I was just given a Herless Vertical Milling machine SM-1 like yours was mine is missing a few parts and in pretty rough shape, but unlike yours I have the ID Plate it says its a SM-1 and the serial number is 85816
    I was wondering if you ever found a place that sold spare parts for it, its missing belts and some are that far gone id like to replace them. On the Id plate at the bottom it had MELB: 560-5655 ( 5 lines )
    Matthew.
    Aug 2015
    843
    Hi Matthew, you can find the belts about. Look on the grizzly site for the same machine and check the specs. They list the belt sizes. They were an A section V belt I recall. I got mind from CBC bearings, but lots of people supply belts.
    One thing about the machine / belts. It always seems that I could never get the belts correct on it. In theory you need two, in practice I found I needed more as (say) the belts you used for the lowest speed were not easy to fit on (say) the fastest speed.
    You say missing some other parts? Not sure what is missing, but those grizzly machines look pretty similar though not sure if I'd bet money that parts were interchangeable with other machines. but ... you never know ....
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    Hi Matthew I have a Herless SM-1 at my work and it takes 'B' section belts. The belts have always been a pain as I've had to use multiple sizes to cover all the speeds. I did a lot of searching on the internet trying to find the belt sizes, but had no luck. Apart from the Grizzly manuals and several others that I looked at I did find one manual that actually had 'SM-1' in it, but it only had belt part numbers which were SM-1052 and SM-1060. I would suggest trying B40, B39 and B35 belt sizes. I would be very interested to know how you go with the belts and if you find two sizes that will allow a full change of spindle speeds without stuffing around with multiple belts.
    I pulled the head of my SM-1 at work apart, because of a bearing noise and it's still apart at the moment. I will be selling mine after I repair it as I've ended upgrading to a secondhand Hafco BM-20E turret mill. If I can help with pictures of parts or dimensions of parts let me know.
    I nearly forgot some of the knee mills like the SM-1 that I looked at it do take A section belts, but the majority were B section belts.
    All The Best steran50 Stewart
    Aug 2015
    843
    hmmm, okay. Maybe they were a B section belt. If so. Ooops.
  1. Looking for a Herless SM-1
    By country kid in forum WANTED TO BUY
    Last Post: 28th Dec 2018, 06:26 AM
  2. Herless K2V
    By stevee7270 in forum METALWORK GENERAL
    Last Post: 2nd Apr 2016, 04:23 PM
  3. VICTORIA Herless Band Saw
    By ersbruce in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Jun 2012, 02:25 PM
  4. New to Me Herless Surface Grinder
    Last Post: 8th Aug 2011, 02:40 PM
  5. Herless Lathes
    By Bidgee in forum METALWORK GENERAL
    Last Post: 17th Jul 2009, 12:05 PM
