Results 1 to 4 of 4
6th May 2018, 11:33 AM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
Those Toy Chinese Plastic Lathes, In action machining aluminium
Hey Guys
took me a while to get a one whole video of the lathe in action, this aluminium was annealed for 5mins with a blow torch than dunked in cold water actually under a running tap
i haven't used the lathe in a while and when i started the bit was blunt scroll forward to see it cutting better, in the video i was making a bearing spacer that holds the yamaha needle bearings in place the spacers is pushed out the side of the piston with the piston pin, its basically just a tool to hold the bearings in place
quiet a long video 30mins in the end i ended up making another piece as this lathe is no good for cutting off pieces however it does machine it well
https://www.youtube.com/watch?v=iz3ZZ6FlmIs
6th May 2018, 02:20 PM #2Member: Blue and white apron brigade
- 7,183
Whoa - I couldn't stand that noise. Is it really that bad?
Lathe work to me is super quiet time, well maybe with some light classical music playing in the background.
6th May 2018, 02:32 PM #3Most Valued Member
- 5,945
Yep, that's the noise they put out Bob. I couldn't stand the one I had here, either, plus spend half a day to take of about 2 mm of hair.
I was glad when my brother asked for it back.
6th May 2018, 08:38 PM #4Most Valued Member
- 4,887
If you found that enjoyable as you probably did just imagine how much more pleasure you would have with a lathe that has power feed and can machine 2/5 mm of aluminium in one pass.
Large plastic chopping board at ALDI - good plastic stock
By pippin88 in forum METALWORK GENERALReplies: 1Last Post: 3rd Jul 2017, 10:24 PM -
Chinese lathes? specifically the CQ-6230A
By mattybgt in forum METALWORK GENERALReplies: 27Last Post: 10th Dec 2016, 11:32 AM -
Tips for Machining PVC Plastic
By Jarh73 in forum METALWORK GENERALReplies: 10Last Post: 26th Jun 2013, 09:02 AM -
Machining Sticky Aluminium
By RayG in forum METALWORK GENERALReplies: 15Last Post: 21st Mar 2011, 07:39 AM -
For those buying lathes or adventuring into machining..
By Article99 in forum METALWORK GENERALReplies: 2Last Post: 6th May 2007, 12:03 AM
