Results 1 to 8 of 8
27th Apr 2018, 11:10 PM #1Golden Member
- Aug 2015
- Melbourne, Australia
- 843
metric Uk bridgeport - acme or trap leadscrews?
Hi all,
Just doing a cleanup and inspection on a 1981 UK metric BP. Screws are not tooo bad but nuts are not very good.
Anyone know if the leadscrews on a metric BP are 29deg acme form or 30deg trapezoidal form?
Many thanks,
Greg.
28th Apr 2018, 08:46 PM #2Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
No idea as to metric or imperial, but if you measure the pitch over 10 or more threads that should enable you to tell what variety you are dealing with.
28th Apr 2018, 09:16 PM #3Most Valued Member
- Jul 2016
- 35
- 1,522
Sorry bob, how would measuring the pitch tell you the flank angle, I think the issue is He doesnt know what the flank angle is.
29th Apr 2018, 08:11 AM #4Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Metric has 30 degree flanks imperial has 29 degree.
29th Apr 2018, 10:09 AM #5Golden Member
- Aug 2015
- 843
Thanks Bob, I do know the pitch. It is 5mm vs the 5 tpi of an imperial BP. It is not a given that because it is a metric pitch it has a 30 degree angle. It could be a 5mm pitch cut using the 29deg acme form. I also asked this over on PM and a fellow from the UK says he measured it and it was 29, not 30. The reason I ask is that, depending of what else need fixing on this BP I may or may not have the budget to buy new nuts. I guess this is some research into 'if I made them myself ... etc'.
29th Apr 2018, 10:51 AM #6Senior Member
- Castlemaine
- 244
Greg,
If you have the screws out of the mill you are welcome to use my Optical Comparitor to check the thread angle.
Cheers Piers
29th Apr 2018, 03:50 PM #7Golden Member
- Aug 2015
- 843
How can I say no to that! Thank Piers that would be amazing. I do have the screws out. I'll PM you.
30th May 2018, 07:36 PM #8Golden Member
- Aug 2015
- 843
the "big reveal" ... the winner is:
First, a big thank you to Piers for spending time with me on his awesome optical comparator trying to discern 0.5deg on a worn leadscrew. Not easy. Although not conclusive, we felt it was more likely ACME than trap.
Thanks Piers, it was a great experience and I learned stuff. I owe you one.
BUT .... I contacted Hardinge .. who contacted their "UK friends" to see if we could get an answer. It took a couple of weeks of emails .. but ... dignitaries, ladies and gentlemen, boy and girls. It is ACME. Here is a snippet of their manufacturing spec.
case closed. )
Greg.
Thanks again Piers.
Acme LH 7/8" x 4 tpi nut
By bob ward in forum METALWORK GENERALReplies: 9Last Post: 14th Oct 2015, 11:47 AM -
Where can I buy Affordable Acme Threaded Lead Screw & Flanged Acme Threaded Nuts
By RoyG in forum METALWORK GENERALReplies: 8Last Post: 1st Sep 2014, 12:26 PM -
3/8-12 acme tap
By rusel in forum METALWORK GENERALReplies: 5Last Post: 23rd Mar 2012, 02:39 PM -
ACME 1/2 - 8 LH rod available ?
By morrisman in forum METALWORK GENERALReplies: 32Last Post: 1st Dec 2011, 10:22 AM
