Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Mar 2016
    Sutherland Shire, Sydney
    24
    Hi Simon, will the motor & pump take pulleys - you could sit them side by side and thus achieve the direction of tvl you want?
  2. #17
    Aug 2011
    4,779
    Hi there,
    I had thought about a pulley or a gear system. If any I think it would have to be geared as I think the bearings on the pump are only designed for axial loads and not side or radial loads that would be generated with a pulley setup. It's certainly more work than I'm prepared to do.
  3. #18
    Apr 2012
    Healesville
    2,129
    Simon l know that you like a chalenge but l have some starter motors from ride mower engines, they turn anti clockwise but will run either way.
    If one will suit and if you want one l will photo them and you can take your pick.
    Shed
  4. #19
    Aug 2006
    1,106
    Wouldn't a starter motor have relatively low duty cycle?
  5. #20
    Aug 2006
    1,106
    Out of interest, is there any reason for the 12 volt motor? How were you powering the this motor before?
    Have you considered single phase AC motors or treadmill DC motors?
  6. #21
    Aug 2011
    4,779
    Quote Originally Posted by Com_VC View Post
    Thanks Shed. I will keep that offer in mind. I will exhaust all avenues with this motor first.
    Hey VC the reason i want to keep the 12v motor is because i will be using the hydraulic pump to drive a small ram that will be a log lifter for my hydraulic log splitter.
    Im not sure ab induction motor would work too well with this particular pump because the motor only runs when you actually extend or retract the ram as opposed to a regular type setup where the motor and pump run continuously and circulating fluid in byepass until a spool valve is pressed.
    As such the motor in this setup needs alot of start torque. I think an induction motor may stall if it starts under a load. An AC universal motor from a washing machine would be a better match in terms of running it from 240V.
  7. #22
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Sounds like a perfect match for a starter motor - maybe a geared one. If you got one from a modern Subaru or similar that's designed to stop and start at traffic lights, they are designed for a surprisingly good duty cycle....
    Cheers, Joe
    Cheers, Joe
  8. #23
    Aug 2011
    4,779
    Stand by everyone. I am going to try rotate the brushes. I'm back at work now so I will not be able to do much more for a couple of days. I will report my results then.
  9. #24
    Aug 2011
    4,779
    Success. I finally got around to trying some changes on this motor. My idea ended up working. I rotated the entire brush assembly by 90 degrees (for a 2 pole motor it would have been 180 degrees)
    This required cutting and extending one of the brush wires to reach and drilling 3 new holes in the motor body.
    Internal clearances between ground and 12v is a bit closer than before and if it was a 240v motor it would be potentially a safety issue but should get by on this occasion.
  10. #25
    Dec 2013
    Sydney
    201
    Does it run though? And in the right (wrong) direction?
    Graham.
  11. #26
    7,189
    Good work simon. I'll be storing that in the grey matter archive for the future.
  12. #27
    Aug 2011
    4,779
    Thanks Bob.
    Graham, yes and yes.
  1. Help needed identifying this DC motor Specs
    By simonl in forum ELECTRICALS
    Last Post: 7th Dec 2017, 04:26 PM
  2. Bridgeport x-axis DC motor needed.
    By caskwarrior in forum METALWORK GENERAL
    Last Post: 6th Aug 2017, 07:04 PM
  3. Can the direction of this electric motor be changed?
    By Com_VC in forum METALWORK GENERAL
    Last Post: 8th Nov 2015, 09:58 PM
  4. Replies: 26
    Last Post: 14th Aug 2015, 02:38 PM
  5. Motor direction
    By Steamwhisperer in forum METALWORK GENERAL
    Last Post: 15th Feb 2012, 05:20 PM
