Results 1 to 9 of 9
Thread: 4 Jaw Chuck Question
24th Apr 2018, 11:56 AM #1Member
- Jul 2003
- 53
- 67
I've recently been given an older little metal lathe, it came is a 100mm 3 jaw chuck.
I am looking to purchase a 4 jaw independant chuck for it. The backing plate on the lathe has 3 holes not the more common 4 hole layout.
I am struggling to find a 100mm 4 jaw with 3 mountng holes. Can anyone suggest an online supplier? or should I look at replacing the faceplate as well?
I've attached the only pic I have of the lathe at this stage.
24th Apr 2018, 12:43 PM #2Most Valued Member
- 4,890
If the mounting plate that the 3 jaw chuck bolts too is able to be removed from the spindle you could either drill 4 new mounting holes to suit the 4 jaw or just make or get made an new backing plate to suit the chuck and spindle.
Not sure of your type of mounting but if you wanted to often change between the two it would be better to have the chucks mounted to their own backing plates.
24th Apr 2018, 12:51 PM #3Golden Member
- Oct 2001
- ACT
- 667
the chuck backing plate is usually fitted to each chuck so you probably need another for the four jaw.
not familiar with these lathes but I assume the chuck/backing plate will unscrew.
26th Apr 2018, 07:23 AM #4New Member
- Jan 2014
- Brisbane
- 5
That looks like the BV 20 Chinese lathe I started with a while ago.The chuck backing plate is a fixture to the spindle(don't bother asking how I found out!) I had to turn up an intermediate 4 holed plate to fit the 4 jaw .Three additional holes were then added to match the non detatchable backing plate.Never worked out why they made them like that.
26th Apr 2018, 12:07 PM #5Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Was on my way to post this in the Ebay / Gumtree thread but figured might put it here also since your looking for a 4 jaw and in Melb
https://www.gumtree.com.au/s-ad/chel...cks/1181539665
Might have something that could be of use ?
26th Apr 2018, 12:35 PM #6Member
- Jul 2003
- 53
- 67
26th Apr 2018, 03:41 PM #7Member
- Jul 2003
- 53
- 67
26th Apr 2018, 04:35 PM #8Diamond Member
- Aug 2006
- 1,106
26th Apr 2018, 05:37 PM #9New Member
- Jan 2014
- Brisbane
- 5
A friend with a small engineering business turned it up on his lathe out of a piece of mild steel plate.We then fitted it to the BV20 spindle and faced it off.Finally drilled the holes to mount the 4 jaw chuck.
Question about way to modify the rear of a small chuck to suit a Toyo ML-1 Spindle
By SurfinNev in forum METALWORK GENERALReplies: 12Last Post: 23rd Jun 2015, 11:11 PM -
AL960 lathe Chuck question
By thorens in forum METALWORK GENERALReplies: 6Last Post: 14th Feb 2014, 09:57 PM -
ER 32 chuck question
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 24th Oct 2011, 05:56 PM -
Lathe & chuck/jaw gripping question.
By davidjames in forum METALWORK GENERALReplies: 22Last Post: 11th Apr 2010, 09:51 AM -
3-jaw chuck question
By ausdag in forum THE HERCUS AREAReplies: 5Last Post: 6th Dec 2009, 11:25 AM
