Results 1 to 12 of 12
Thread: carbide drill
    Apr 2014
    134
    Default carbide drill
    hi
    will a carbide drill put a hole through a hardened and ground qctp body i need to open the existing hole up
    if so do you go slow or fast
    steve
    Aug 2011
    4,779
    I suspect a properly sharpened HSS drill bit would even do that. What size hole do you need? Is it to fit the post bolt?
    Usually the harder the material, the slower you go. What size hole?
    Jan 2016
    Wodonga Vic
    38
    633
    Can you hold the work in a four jaw and bore it out? you'll get a better finish
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,513
    What size is the hole now and what size do you need? A drill may be the wrong choice for this job.
    Nev.
    Apr 2014
    134
    hi
    yes it is for the hole in the tool post hss will not even look at it
    steve
    Aug 2011
    4,779
    As suggested above, bore it out on the lathe or on a mill. Using a drill bit is not the right tool for the job.
    Apr 2014
    134
    hi
    a hss drill bit wont touch it so why will putting it in the 4 jaw chuck and trying to bore it with hss work
    steve
    Jun 2007
    sydney ( st marys )
    64
    4,890
    It probably wouldn't but you never know,
    An indexable bar would probably be the better option.
    How big is the bore at present?
    Are you able to machine a new mounting stud to suit your tool post?
    Apr 2014
    134
    pipeclay
    i think i will have to make a new stud i dont have any carbide or tip tooling and all i wanted to know was if a carbide drill would go through hardened steel
    if it did i would have brought one
    thanks steve
    Jun 2007
    sydney ( st marys )
    64
    4,890
    If the carbide drill is an option to you check the price of a boring bar as well as these days they can be found quite cheaply, sometimes they may even come with one or two inserts.
    Mar 2014
    South of Adelaide
    1,227
    Need more information. It really depends on what equipment you have and how much you need to open up the hole and what equipment you have. Drilling a 12mm hole out 18mm in the machining center at work* no problems. Going from 12mm to 13mm in a drill press, not going to work.
    *The drill for doing that would be about $200.
    Nov 2008
    70
    1,513
    Would a carbide burr work if there's one a suitable size? I was thinking one with a cone shape may work.
    Nev.
  1. Carbide Spade Drill Bits
    By Chris Parks in forum METALWORK GENERAL
    Last Post: 14th May 2017, 10:36 PM
  2. What carbide tip is this?
    Last Post: 16th Nov 2009, 10:12 PM
  3. How Do I Sharpen Solid Carbide Drill Bits?
    By mike48 in forum METALWORK GENERAL
    Last Post: 13th Oct 2009, 12:21 AM
  4. Carbide
    By jackaroo in forum METALWORK GENERAL
    Last Post: 21st Sep 2007, 09:48 PM
