Results 31 to 34 of 34
21st Jul 2018, 09:27 PM #31Novice
- Apr 2018
- Hobart, Australia
- 38
- 24
Hell all, so am thinking of replacing the motor on the lathe, Current motor is 2HP 1100rpm
Should I stick with a 2HP motor or should I upgrade to a 3HP one?
21st Jul 2018, 09:41 PM #32Most Valued Member
- Jul 2016
- 35
- 1,522
If whats on it spins, id use it. save your money for tooling.
21st Jul 2018, 10:29 PM #33
I'm with Caskwarrior. Tooling can eat up quite a bit of cash. You will probably be surprised how good a part you can make with this as is.
As prev mentioned you can adapt your methods (to a point), to cater for inaccuracies.
Wouldn't be the first time I have employed the odd shim here and there to get the job done.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
22nd Jul 2018, 08:03 PM #34Novice
- Apr 2018
- Hobart, Australia
- 38
- 24
I only have single phase in my workshop, current motor is 3phase. im planning to get a VFD to run it but the current motor seems to have the star/delta connection within the motor so is not a easy conversion...
From the small amount of literature I could find on Nuttal Lathes they either came with or had the option for a 2 3/4 HP motor.
The VFD Im getting can handle 3hp so if I do need to get a new motor was thinking why not upgrade a little? Also with the VFD when running below 50hz you do not get the full HP out of the motor right? so with the 3HP would still have good power at lower hz
Restoring an old mill
By Alf Scotting in forum METALWORK GENERALReplies: 17Last Post: 1st Feb 2017, 12:16 PM -
Worth a laugh - fresh painted ways on for-sale lathe
By StrayAlien in forum METALWORK GENERALReplies: 10Last Post: 4th Sep 2016, 09:27 PM -
BV20B Lathe whats it worth....
By joez in forum METALWORK GENERALReplies: 2Last Post: 26th Aug 2011, 10:36 AM -
What's an Emco compact 8 lathe worth?
By neksmerj in forum METALWORK GENERALReplies: 33Last Post: 7th Apr 2011, 11:06 PM
