Results 1 to 15 of 28
Thread: Removing tables from HM52 mill
8th Apr 2018, 01:50 PM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
The Y axis on my Hafpos HM52 has suddenly decided to become almost impossibly stiff to wind back and forth. I can't see anything obvious, gib screws are still in place and tight, I'm thinking that chip has worked its way somewhere it shouldn't be so I'll remove the tables and investigate.
It shouldn't be too hard, start from the top and burrow down, but if someone can share a few words of wisdom it will be appreciated.
8th Apr 2018, 02:27 PM #2
Hi Bob,
I struck the same on a HM52 at a school where I worked.
It had not been used for a while and it was found that the oiler was blocked -so no oil and the coolant had caused rust over the drive screw thread.
There was a hard crusty orange rusty patch on the thread.
8th Apr 2018, 02:28 PM #3
Hi Bob
Undo the 4 nuts for the swivel, and the table and upper saddle will all come off together. There is a pivot spindle in there that is pressed into the lower saddle from memory.
Then you can get to the lower saddle where you will find the Allen head bolt for the Y axis nut. I'll grab some pictures for you.Using Tapatalk
8th Apr 2018, 02:37 PM #4
Here are some pictures
Using Tapatalk
8th Apr 2018, 02:41 PM #5
While I was in there I extended the Y axis travel to around 280mm.
I made new sheet metal covers and added a millied block to the front. I also had to remove a little cast on the knee slot to allow the nut to come further forward.Using Tapatalk
8th Apr 2018, 03:00 PM #6Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi Dave,
Great to see you back posting again-I know you have been doing it for a while I have just been a bit slack. I remember when you did the total rebuild of your mill, fantastic workmanship, nice to see it again.
Regards Bob
8th Apr 2018, 04:42 PM #7
8th Apr 2018, 05:00 PM #8Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Wonderful info Dave J, many thanks.
8th Apr 2018, 05:14 PM #9Diamond Member
- Aug 2006
- 1,105
Have you tried the photobucket fix? https://chrome.google.com/webstore/d...giikdkpmcpkaon
8th Apr 2018, 05:18 PM #10
8th Apr 2018, 05:25 PM #11Diamond Member
- Aug 2006
- 1,105
If you give me a thread link that you are having problems seeing the photos I will let you know if it works for me.
8th Apr 2018, 05:47 PM #12
The photo at the bottom of this thread doesn't show up
//metalworkforums.com/f65/t1219...te-12x36-latheUsing Tapatalk
8th Apr 2018, 05:54 PM #13Diamond Member
- Aug 2006
- 1,105
There is a photo in the first post that works, but no photos in the other posts.
http://i990.photobucket.com/albums/a...=1523170391978
8th Apr 2018, 06:42 PM #14
10th Apr 2018, 01:55 AM #15Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
That was straightforward but.....
I followed Dave J's suggestion and lifted the table and swivel off as one to expose the Y axis.
Removing the gib and sliding the Y axis well forward reveals swarf that has got past the wipers. I suspect the swarf was balling up and jamming the Y slide, the slide only has 2mm clearance over where the swarf is. This is a 10 year old mill so maybe that collection of swarf isn't too bad for that period of time. I cleaned everything and reassembled the Y slide and it all works as well as it used to.
BUT. From new, Y axis travel has always been a little stiff at the hand wheel end, I was hoping to solve that annoyance while sorting out the serious jamming. Making sure that the screw (28 x 4 trapezoidal) and nut were scrupulously clean I ran the nut on from the LH end and encountered resistance near the RH end, the hand wheel end. W T F? The screw is dead straight, all I can think is that the thread is out of spec at the end. Any thoughts or experience?
Electrician to repair 240 volt HM52 mill Western Sydney
By pipeclay in forum ELECTRICALSReplies: 2Last Post: 17th Apr 2017, 07:29 PM -
Rotary Tables
By simonl in forum METALWORK GENERALReplies: 104Last Post: 22nd Jan 2013, 10:18 AM -
Posting tables
By duncang in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 4th Jan 2012, 10:48 PM -
Removing mill scale?
By Mathuranatha in forum WELDINGReplies: 1Last Post: 19th Dec 2010, 12:50 PM -
Removing Mill Motor
By electrosteam in forum METALWORK GENERALReplies: 7Last Post: 10th Jul 2010, 09:54 AM
