Results 1 to 13 of 13
    Apr 2010
    Bundoora, Victoria
    20
    Default Help identifying model of Her less mill
    Hi all
    Long time member and lurker but first time poster.
    I've recently inherited a Herless vertical mill but there's no tag with the model number. It has a Compton Parke's single phase motor. There is up and down movement in the shaft inside the quill that I obviously need to remove but am a bit insure at this stage how. Please excuse me if I use the wrong names but I'm new to milling.
    I'm hoping somebody here can help me identify the model so I can attempt to find an exploded view and/or manual. Picture for information. It was originally a blue/green light hammer finish but my uncle seemed to repaint almost everything grey.
    Thanks in advance...Andrew
    Jan 2012
    149
    Hi Andrew.
    Looks like a Herless RF30.
    Made by Rong Fu
    Neil
    Apr 2010
    Bundoora, Victoria
    20
    Thanks Neil. I actually found can reference to an RF30a last night and tend to agree with you. Any idea where I could find a manual? I'm new to milling but having a ball. My uncle tended to get lots of accessories for anything he bought so I've got plenty of cutters. Same goes for the Wabeco lathe as well as a multitude of Stahwille, Bacho and Britool spanners. He was a bachelor and worked as a mechanic and engineer all his life. The collection was split between 3 and I don't think I'll ever have to buy another tool. Having fun as I'm on long service leave and retire in 2 weeks. Never been busier. Cheers...Andrew
    Dec 2005
    South Australia
    1,657
    Looks very similar to mine, Long Chang Machinery Co. ( Taiwan ) even though mine is old I sent them a email with the detail and the sent me a PDF of the manual, I would send you a copy however it is on my old other computer and
    I am having a great amount of difficulty retrieving any data from it
    Apr 2010
    Bundoora, Victoria
    20
    Thanks China. It could be Chinese but knowing how my uncle was he wouldn't buy it. I know he had it about 45 years but that's all I know. Should have asked him before he died. Not sure whether he bought it new.
    Dec 2005
    South Australia
    1,657
    It is without a doubt Chinese/Taiwanese, it is just branded Herless, the one I have is at least 20 years old (not Herless)
    6,475
    Quote Originally Posted by China View Post
    Take the HDD out and put it into a USB case ! As long as the HDD isn't faulty you should be able to use it as remote storage.
    Dec 2005
    South Australia
    1,657
    Thanks BaronJ.
    may give that a try I have 3 000 photo's I want to retrieve among other things, a over the phone diagnosis is the hard drive may be mechanically worn out.
    6,475
    Hi China,
    I've yet to see a mechanically worn out HDD ! Crashed, Yes, dropped or otherwise damaged, Yes !
    I would suggest that the most common failure mode for a HDD is electronic. With the advent of "Lead Free" solder, cracked or dry joints are more likely. The most common place for this kind of failure is right behind the connectors, where some movement can take place when the plugs are inserted and removed.
    Before anybody else comments, yes, cracked solder joints are a mechanical failure, rather than worn out !
    I have in the past swapped a bad circuit board out for a good one, just to recover a users data. Sadly that doesn't always work ! There is at least one IC inside the drive that can suffer failure. Once that dies the drive is toast, unless you are a very rich man.
    Dec 2005
    South Australia
    1,657
    Thanks BaronJ Iwill do some investigation
    Jun 2007
    Vic
    48
    544
    Hi China, If the HDD is not reading then try to wrap it up with zip bag and put in freezer for 30 minutes or so then try again. that saved me a few times in the past.
    Hi Andrew, I used to have the "Rong Fu FR30" too, made in the 80s by Taiwanese. Try this link for the manual
    Nov 2005
    adelaide
    597
    i have a rebranded rf25 new sticker with hercus label so should be ok
    Apr 2010
    Bundoora, Victoria
    20
    Hi Jackaroo.
    Thanks for the link. Your blood's worth bottling. A couple of differences but so close it will do. Much better than what I've got which is nothing. Thanks again...Andrew
  1. Help Identifying small Horizontal Hobby Mill
    Last Post: 6th Jul 2017, 04:40 PM
  2. Hercus Model O mill Yarraville Vic Ebay 04 Aug.
    By zbm in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 4th Aug 2016, 09:11 PM
  3. Hercus Model O Mill Manuals
    By bwal74 in forum THE HERCUS AREA
    Last Post: 1st Jan 2013, 10:27 AM
  4. Arboga EM825 mill vs Hercus model 0 mill?
    Last Post: 14th May 2011, 03:16 PM
  5. Hercus mill, Model 0
    By larry2721 in forum THE HERCUS AREA
    Last Post: 7th Feb 2011, 10:21 PM
