Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Nov 2008
    Perth WA
    6,459
    Thank you Rob.
  2. #17
    Apr 2013
    Mornington Peninsular
    23
    I was also wondering about the chamfers. I can never get them even and it makes everything look out of square. Lovely work.
    I’ve also often wondered when you would use a horizontal over the vertical mill - doing the vee slots is a perfect example. I have the horizontal arbor bearing support for my 13 and will eventually get around to making the arbor and getting some tooling.
    How does the optical microscope work? I presume you don’t have a DRO on the Y axis.
    Leigh
    Sent from my iPad using Tapatalk
  3. #18
    Nov 2008
    Perth WA
    6,459
    Default Part 2
    I had planned to make an adaptor for my Ifanger threading tool if the retractable worked. So here is the adaptor. The shaft is 4140, the end block, 1045 and the shoe, 1214. The shaft and its 12mm diameter extension were ground to size using the Hercus T and C as a cylindrical grinder. With a tenth dial indicator set up on the Y it is possible to acheive an infeed of less than 0.0001". Without the indicator it's hit and miss with the misses prevailing. The little Douglas provided a nice finish to the 1045.
    DSC_9218 (Large).JPG DSC_9222 (Large).JPG DSC_9226 (Large).jpg DSC_9233 (Large).JPG DSC_9237 (Large).jpg
    IMG_20180412_123030765 (Large).jpg IMG_20180412_123041606 (Large).jpg IMG_20180412_132149920_BURST000_COVER (Large).jpg IMG_20180413_150438145 (1) (Large).jpg
    BT
  4. #19
    May 2011
    Castlemaine
    244
    BT,
    I would score that 11 out of 10
    Excellent photos as usual.
    Piers
  5. #20
    Oct 2010
    NSW
    181
    "with the misses prevailing"
    Yep, I know the feeling, the misses frevails around here too Bob.
    Great photos and work BTW.
  6. #21
    Jun 2004
    Kyabram. Vic
    632
    Very nice Bob.
    Ken
  7. #22
    Oct 2008
    N.W.Tasmania
    1,407
    Quote Originally Posted by Picko View Post
    I think that they prevail everywhere.
    Beautiful work and photos there BT, congratulations,
    Rob.
  8. #23
    Apr 2009
    Ballina N.S.W.
    644
    Hi BT,
    Somehow I missed your original post on this tool. Excellent work and photos, both of which are constantly improving.I especially like how you have the threading tool mounted as far forward as possible.
    Bob
  9. #24
    Aug 2011
    4,779
    Hi Bob,
    Sorry about the late reply. That tool holder is a work of art. You certainly are a master in the shed, and your photography is something that Donna Hay would be proud of. Thanks for posting AND thanks for being a continual source of inspiration.
  10. #25
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by Ambrosia View Post
    Leigh
    My apologies for the tardy response Leigh and a warm welcome to this forum. For some weird reason notification of your post only appeared yesterday in my gmail inbox???
    The small chamfers are roughly 45 degrees. I used a little protractor to position the holder in the vice at 45 degrees and then tried as best I could to hold the file flat. Seems to have worked well enough.
    I don't often use the mill in the horizontal mode but for the retractable's major vees it was essential.
    You are correct, my 13 is DRO-less. The optical micrometer was discussed in some detail a few years back - //metalworkforums.com/f65/t170823-optical-micrometers-chance-alsace/latest/post1653664#post1653664
    The thread is devoid of photos showing the device's innards so the photos below might help. The micrometers shown are metric. The silver micrometer on the mill was originally imperial and I have swapped its graduated bezel and cam with those from the better of the two metric mics.
    Getting the micrometer to focus and provide a usable image was another challenge -
    //metalworkforums.com/f65/t191468-eccentric-adjuster-optical-micrometer/latest/post1834851#post1834851
    Bob.
  1. CXA threading tool ?
    By topari in forum METALWORK GENERAL
    Last Post: 17th Mar 2018, 09:13 AM
  2. A simple recessing tool
    By bob ward in forum METALWORK GENERAL
    Last Post: 13th May 2016, 09:10 AM
  3. My first contribution....simple tool holder
    By John Hill in forum METALWORK GENERAL
    Last Post: 8th Dec 2011, 10:12 PM
  4. Simple Lathe Tool Centre Height Gauge
    Last Post: 14th Jan 2011, 05:17 PM
  5. Carbide Threading Tool - Great Value
    By hux in forum METALWORK GENERAL
    Last Post: 26th Sep 2007, 10:57 PM
