Results 1 to 4 of 4
Thread: Spindle taper I.D. ?
18th Mar 2018, 11:40 AM #1
Hi ,
Looking at this spindle . The chap is not sure and all he says it is a quick change chuck. What type of spindle taper would it be ? MT maybe. It's a SIMA vertical milling machine from the 1950's or 60's. Thanks Mike
18th Mar 2018, 12:31 PM #2Senior Member
- Sep 2007
- Country West Oz
- 77
- 169
That looks like a key less drill chuck, be hard to say what the taper is. A machine I had years ago had a chuck like that and it was threaded on similar to portable drill.
BTW Thanks for the valves, I will put them to good use.Regards
Bradford
18th Mar 2018, 12:39 PM #3Senior Member
- May 2015
- Richmond
- 214
S.I.M.A. Rossi Milling machine
maye be of use. This suggests ISO 30.
18th Mar 2018, 04:19 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
You are going to have real trouble identifying it without seeing the tooling, jig borers have used some strange stuff
Cat 30 taper spindle
By Mike4 in forum METALWORK GENERALReplies: 4Last Post: 16th Oct 2015, 11:07 AM -
Repair/Regrind drill spindle taper
By wsal in forum METALWORK GENERALReplies: 10Last Post: 17th Dec 2014, 07:56 PM -
Taper Pins and taper pin reamers
By tbonesmith in forum METALWORK GENERALReplies: 4Last Post: 14th Apr 2014, 02:49 AM -
Lathe spindle taper bearing end playadjusment
By iron bark in forum METALWORK GENERALReplies: 7Last Post: 7th Jan 2014, 10:37 PM -
Spindle taper size
By TomW in forum THE HERCUS AREAReplies: 5Last Post: 24th May 2012, 05:02 PM
