Results 16 to 29 of 29
Thread: Toyota LSD design issues
25th Mar 2018, 07:35 PM #16Intermediate Member
- Feb 2018
- Loxton
- 54
- 37
I presume the gearbox upgrade would be fitting the one out of the latest model, which drops the revs?
Cheers Andrew
27th Mar 2018, 08:13 PM #17
AJ, Thats what I am checking out ,lot of work as the clutch will be replaced while the gearbox is out if I proceed,
27th Mar 2018, 08:16 PM #18
Around $1745 with freight . its in and already making a difference , engine is not working as hard,
Using less fuel , 150 kllms now only 1/4 tank as previously nearly 1/2 tank.
27th Mar 2018, 08:34 PM #19Diamond Member
- N.W.Tasmania
- 1,407
Going from the time stamps of your last two posts, you didn't pi$$ around much deciding what you were going to do, you just made your mind up and went ahead with it and job done in 3 minutes!
With a work ethic like that, some of the F1 teams would be interested in your expertise I'd say. A very fine effort.
Rob
28th Mar 2018, 10:04 AM #20
No , I had a chance between jobs to update .
So far I am happy with the results , also I possibly saved a $1000 or more doing the install myself as well as about 3-4 days .
Nothing happens quickly in most mechanical shops , many dont care about vehicles either as they all think that if a vehicle has more than 40 thousand klms on the clock it worn out and they have no respect for it.
Happened with dealer , thats why I do my own servicing .
28th Mar 2018, 10:15 PM #21Most Valued Member
- 5,945
1st Apr 2018, 03:08 PM #22
Kryn,
Just the replacement of a stuffed LSD with a Terrain Tamer E locker .
The oils was black and gritty , once it settled I found that the grit was particles from one of the clutches ,it was running that hot the oil had cooked .
Now when only have done around only 300 klms axles etc are cool compared to the previous week where everything was uncomfortable to touch after 200klms or so and i had a 600 klm round trip to complete.
The gearbox will have to wait as I am starting to get busy again and should be until at least october November.
Lots of changes to equipment for customers so that their gear is compliant .
1st Apr 2018, 03:56 PM #23Pink 10EE owner
- 6,216
I take it must be a landcruiser with a turbo motor. The ones with the 1HZ motor had a weak gearbox. Ok for light duty work, but poor for heavy work.
https://www.youtube.com/watch?v=4tdparM6oK4Gold, the colour of choice for the discerning person.
1st Apr 2018, 05:57 PM #24Diamond Member
- Aug 2006
- 1,105
If it is one of the current ones it should be a V8 turbo diesel.
16th Apr 2018, 04:28 PM #25
Yes its a 2011 V8 diesel , just spent Sunday night swapping out the Fan clutch which decided to spit it fluid out .
This one is a pain to get to as I dint have small hands with inbuilt tools.
Did end up cleaning the radiator as well while all the guards were off the bottom .
The Dayco replacement is better than the original as it spins the fan at highway speeds ,something I prefer as it keeps the engine a bit cooler.
I would like to find a suitable electric clutch which would allow more control but this will do for the moment.
16th Apr 2018, 10:57 PM #26Golden Member
- Vic
- 48
- 544
Hi Michael, I am assuming the ratio is the same on the new diff, should the engine load just be the same as the old diff? Diff locker should be off all the time unless you are driving slow and experiencing free wheeling/no traction on one side?
Regards,
Trong
23rd Apr 2018, 10:47 AM #27
Depends on how hard the shaft is to fit as normally I can only have the ute out of action for a couple of days,
The full gear box is around $4500 and you have to sent your old one back to them .
23rd Apr 2018, 10:50 AM #28
The locker was fitted with the original pinion and gear, the problem with the LSD was that it was slipping and occasionally grabbing during normal driving , it got to the stage that I could not touch the housing after only 3-400 klms.
Now its quiet and cooler.
10th Jun 2018, 10:50 PM #29
Just an update on the locker, I have a bit over 4000k on it now , no noises or any crunchy bits.
Happy so far , will need to use it shortly when I go to one site with a trailer in tow .
Toyota forklift handbrake
By caskwarrior in forum METALWORK GENERALReplies: 11Last Post: 7th May 2017, 01:15 AM -
2002 Toyota Hilux ute tub into a trailer
By Garry Edwards in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 15th Jan 2015, 12:11 AM -
Steel Tray for Toyota Hilux
By fransjordan in forum METALWORK GENERALReplies: 10Last Post: 27th Nov 2013, 10:33 AM -
Finding Engineering Design Software For Automatic Machine Design
By davidWilliams in forum METALWORK GENERALReplies: 2Last Post: 11th Jan 2010, 10:41 PM -
6 stud toyota stub axles for trailer
By YarrD in forum TRAILERS & OTHER FABRICATED STUFFReplies: 35Last Post: 10th Aug 2009, 11:59 PM
