Results 1 to 13 of 13
Thread: What Type Of Steel Is This?
17th Mar 2018, 09:07 PM #1
What type of steel is this?
I found 3 of these 100 mm dia, I am guessing they where form earth moving equipment.
My bandsaw hardly mark it, even with a new blade on it.
I tried cutting down about 4 - 5 mm with an angle grinder but made no difference.
17th Mar 2018, 09:24 PM #2China
- Dec 2005
- South Australia
- 1,656
Impossible to tell from a photo a guess would be something that has been case hardened
17th Mar 2018, 11:25 PM #3Most Valued Member
- 5,942
Mark, it's very hard steel.
It actually looks like a pin from an excavator bucket or similar.
As to the type, it would be anyones guess, probably be a job for a metalurgist to work that one out.
18th Mar 2018, 07:57 AM #4Most Valued Member
- Jul 2016
- 35
- 1,522
You could try tempering them a bit in a wood stove or similar if you have access.
18th Mar 2018, 08:24 AM #5Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
That pin is case hardened. You will struggle to do much with it unless you have a beefy lathe and CBN tools to turn the case off. with out a spectrogragh its impossible to tell what grade it is, but by guess would be 1045,4140 or something similar.
18th Mar 2018, 09:20 AM #6Pink 10EE owner
- 6,216
18th Mar 2018, 09:59 AM #7Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
I have case hardened 4140 and 4130 without a problem.
18th Mar 2018, 12:45 PM #8
18th Mar 2018, 12:47 PM #9
18th Mar 2018, 12:52 PM #10
18th Mar 2018, 02:59 PM #11Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
18th Mar 2018, 03:32 PM #12Pink 10EE owner
- 6,216
I did an experiment some years back. A piece of 4140 and mild steel, in a charcoal based case hardening mix together. Then quench hardened.
The mild steel measured at Rockwell 60 afterwards, the 4140 only 50. No more then just a normal quench would have achieved without case hardening.Gold, the colour of choice for the discerning person.
18th Mar 2018, 06:55 PM #13Senior Member
- Jul 2012
- Griffith NSW
- 435
A mob in my town makes replacement pins for excavators and farm equipment. They machine them from 1050 steel, then send them off for nitriding to achieve the hard case. The pins are returned and then turned to size using CBN inserts.
Hard af.
Type A and Type B assets - Grays online
By simonl in forum METALWORK GENERALReplies: 38Last Post: 1st Oct 2014, 11:04 AM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
What is this type of fastener?
By neksmerj in forum METALWORK GENERALReplies: 16Last Post: 26th Feb 2013, 02:05 AM -
Tap (& die) holders - bar type vs t-bar type
By TheOtherLeft in forum METALWORK GENERALReplies: 26Last Post: 13th Apr 2011, 07:53 PM -
What type of oil can do I need
By 19brendan81 in forum METALWORK GENERALReplies: 6Last Post: 30th Jan 2011, 11:03 PM
