Results 1 to 5 of 5
Thread: What grit stone for scraping?
16th Mar 2018, 06:04 PM #1Senior Member
- Mar 2017
- Brisbane
- 245
Hey all just wondering if you do metal scraping and if so what sort of stone is good for deburring afterwards?
17th Mar 2018, 08:58 AM #2Most Valued Member
- Oct 2007
- 3,112
I use a Norton fine slip stone, before that I used a fine diamond stone. It doesn't matter what you use really, just as long as it's relatively fine and you don't over stone the work. The ideal would be some precision ground stones, but mine are a bit large for that. What you're aiming for is to knock the burrs off without affecting the overall geometry.
17th Mar 2018, 09:46 AM #3Senior Member
- Mar 2017
- Brisbane
- 245
Where did you get it from?
17th Mar 2018, 12:47 PM #4Most Valued Member
- Oct 2007
- 3,112
Enco. They don't exist any more. Just Google a supplier here or buy through Amazon.
https://www.amazon.com/Norton-Shape-...ine+slip+stone
18th Mar 2018, 10:14 AM #5Golden Member
- Aug 2015
- Melbourne, Australia
- 843
You can get the stones from mcmaster carr in the US if you have a US postal address for forwarding. Though, I'm no expert (no scraping experience at all - so I'll defer to others here) but Connolly just uses a 'burr file'. After reading his book I made one from an old file (took 10 minutes) and it is one of the handiest things in the workshop. No harm or scratches to anything except the burrs and when there are none you can hear the difference in sound it makes as it 'whistles' across the surface.
Selecting the right grinding grit
By KBs PensNmore in forum GENERAL DISCUSSION / OFF TOPICReplies: 0Last Post: 24th Oct 2016, 07:35 PM -
Selecting the right grinding grit.
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 24th Oct 2016, 07:25 PM -
Grit Blasting Cabinet.
By BaronJ in forum METALWORK GENERALReplies: 21Last Post: 7th Dec 2015, 09:43 AM -
What grit for carbide tooling
By KBs PensNmore in forum METALWORK GENERALReplies: 3Last Post: 11th Jun 2015, 11:03 AM -
Swiss Scraping or scraping from the shoulder
By Ueee in forum METALWORK GENERALReplies: 3Last Post: 30th Jul 2012, 01:31 AM
