Results 1 to 2 of 2
15th Mar 2018, 10:33 AM #1
Seeking Dimensions for Fragram B131 square stop block
Hi,
I am hoping someone here may have a Fragram Flat Bar and Solid Section B131 bender or a similar clone / copy.
I have lost the square stop block which is steel and has rough dimensions of 50 x 50 x 50 and has a hole drilled in one corner with unequal offsets from the edges.
I have the material to make another but seek those important dimensions.
I am hoping someone can help. If its a clone the dimensions are likely to be the same.
It is one of these. The square block is seen above the post stand.
15th Mar 2018, 11:54 AM #2
Yahoo!
Got one already,
I emailed Fragram with an enquiry for specs. Even though they don't make them now they still had a spare.
$20.50 mailed.
Also they had a manual to download from their website. Made it dead easy to order.
I am impressed with their lighting response and availability of parts.It is so refreshing to see.
Seeking a Source of M 10 Nuts .
By Anorak Bob in forum METALWORK GENERALReplies: 20Last Post: 8th Jul 2015, 10:35 PM -
"How to make a stop block assembly"
By KBs PensNmore in forum METALWORK GENERALReplies: 14Last Post: 15th Feb 2015, 01:23 PM -
Square tubing that's not square
By Corgan in forum METALWORK GENERALReplies: 18Last Post: 1st Nov 2011, 09:31 AM -
Table square block for miller
By Grahame Collins in forum METALWORK GENERALReplies: 14Last Post: 13th Mar 2011, 08:26 AM -
New to milling machines and seeking advice
By elliot42 in forum METALWORK GENERALReplies: 39Last Post: 21st Jan 2011, 09:00 AM
