Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Dec 2013
    56
    1,418
    Are they all the same brand scales?
    Using Tapatalk
  2. #17
    Dec 2010
    Syd
    492
    Quote Originally Posted by TKO View Post
    Well I am back again the problem is the change over from the lathe to the mill Dro,,the X on the lathe is y on the mill as you all will know but to just swap them over does not work ,is it possible to remove the moving reader part of the two glass scales and change them over.would that work .I am up the creek with this now,as I am hoping some one will know how to fix the problem and get me out of the mess I have made of this.
    Eddie
    Not quite following, it's quite common to use a X-Y mill dro on a lathe. If swapping the plugs at the display doesn't achieve the desired result, there's something more than a little weird happening I'd think.
    Can't remember specifics on the Sino now, as it's a bit too far back. On the Easson I do remember, the reader head ships separate to the glass scale, so I'd expect both to be the same and you should be able to swap reader heads between the two scales. Only caution being the various plastic packer pieces, that come with the head to ensure you don't damage the scale during assembly and mounting - I wouldn't like to attempt an installation without having them in place, with Murphy sure to be ready to pounce!
  3. #18
    Dec 2013
    56
    1,418
    I agree, the only thing I can think of is a broken wire connection in the plug, and when moved to the other socket it's not connected. The wires are very thin.
    The plugs are easily taken apart to check.
    I have wiring diagrams for quite a few DROs and scales here, and have changed many round and DB9 plugs over.
    Using Tapatalk
  4. #19
    Jan 2011
    shep Victoria
    97
    157
    I have now found that I can switch the two plugs, ,what I need to know is what can I replace the to short cross slide lathe one with, as it is to short for the mill or does it not really matter what brand I get, I have a Sino Dro there is as has been said a lot of cheaper scales and kits on the market ,thanks for your help.
    Eddie
  5. #20
    Dec 2013
    56
    1,418
    Doesn't matter what brand, other than some high end DROs all scales are 5v TTL signal.
    Look for double lip seals if you can, but single are fine also.
    Using Tapatalk
  6. #21
    Jan 2011
    shep Victoria
    97
    157
    Thanks Dave J.
  7. #22
    Dec 2021
    Perth, Western Australia
    4
    Default SINO DC voltage on DB9 socket
    Hi there,
    Does anyone know what is the DC voltage required to drive the SINO scales?
    I have an old Meister DRO that outputs 2.5V to drive a Meister scale and works fine.
    Have just found-out that an EASSON scale requires 5V. Ouch!
    Regards,
    Pete
  8. #23
    Dec 2013
    56
    1,418
    Yeah 5v, Vevor have a 3 axis readout at the moment with free shipping for $99, that may help and is supper cheap.
    I have at least 1 maybe 2 Mititoyo scales here that I bought years ago new old stock, so I'll have to look into the voltage when I get around to using them.
    Sent from my 5007U using Tapatalk
    Using Tapatalk
  9. #24
    Dec 2013
    56
    1,418
    I think I got that the wrong way around, if you need scales they also have them from around $62 from memory.
    Depending on travel lengths you maybe better off going with a complete new setup from eBay or AliExpress.
    AliExpress ones usually are at the door in 7 to 10 days and I find shopping on there cheaper than eBay with quicker postage.
    I got a good scores from Vevor a few months back picking up 3x 250mm scales for $36 each posted through eBay.
    Using Tapatalk
  1. Easson ES8 DRO playing up
    By bob ward in forum METALWORK GENERAL
    Last Post: 25th Apr 2015, 02:12 PM
  2. How to use an Easson DRO
    Last Post: 16th Jan 2012, 09:46 AM
  3. Fitting a Sino 3 DRO to my AL1000D lathe
    By krisfarm in forum METALWORK GENERAL
    Last Post: 8th Jun 2011, 04:41 PM
  4. SINO vs SINPO DROs
    By Big Shed in forum METALWORK GENERAL
    Last Post: 31st Jan 2011, 05:38 PM
  5. POSSIBLE GROUP BUY - EASSON 3-axis Digital Read Outs
    By markjaffa in forum METALWORK GENERAL
    Last Post: 16th Sep 2009, 10:52 PM
