Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Jan 2004
    Mackay North Qld
    6,446
    Joe , Can you see the pics in post 1?
    In the 1st photo there is a die and die holder laying on the floor under the vice.
    It looks like the style and colour Rigid use, but could well be a knockoff.
    Another thought I had was about how the pipe was held in the vice.
    Was the position of the pipe, axis vertical or axis horizontal? There is more contact area if the pipe is horizontal and less likely to slip.
  2. #17
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    Thanks, Grahame. I only just spotted the die and holder. That should work perfectly fine. Mine look the same. The vice looks a little on the small side - maybe a 3" (75mm) jaw width? I think Tiriaq, that clamping the thin wall pipe horizontally and with a solid piece inside it is your best chance.
    Cheers, Joe
  1. Replies: 5
    Last Post: 11th Sep 2015, 07:22 AM
  2. Pipe joins
    By Legion in forum WELDING
    Last Post: 23rd Dec 2013, 08:43 AM
  3. Pipe bender
    By tinkera in forum METALWORK GENERAL
    Last Post: 1st Jul 2013, 12:27 PM
  4. Pipe Vice-pipe bender identity and info please
    By Log in forum METALWORK GENERAL
    Last Post: 18th Apr 2012, 01:14 PM
  5. Pipe centre
    By Sterob in forum METALWORK GENERAL
    Last Post: 13th Jan 2011, 11:19 PM
