Results 1 to 3 of 3
Thread: Form tool
15th Feb 2018, 10:42 PM #1China
- Dec 2005
- South Australia
- 1,658
Form tool
I wish to grind a form tool (HSS) to create 6mm ball I am planning to grind a radius to suit with a small relief and leave the top of the cutter flat (3/8x3/8 HSS) am I on
the right track or is it not that simple
16th Feb 2018, 12:25 AM #2
Hi China,
Yes ! There are two ways to get to where you want to be. A form tool is just one way. The other is to build a ball turning tool that rotates a cutter, either horizontally or vertically around the end of the workpiece. You could always use a carbide wood router bit with the right shape to do the job. For a one off, that is what I would do.Best Regards:
16th Feb 2018, 02:20 AM #3China
- Dec 2005
- South Australia
- 1,658
Thanks BaronJ. is great idea wish I had thought of it
Big deep cut Vee form tool
By steamingbill in forum METALWORK GENERALReplies: 6Last Post: 25th Mar 2016, 10:13 PM -
Motorcycle bar end form tool
By welder in forum METALWORK GENERALReplies: 4Last Post: 23rd Mar 2016, 08:28 PM -
Tool grinding: Form cutter sharpening attachment
By WoodBee2 in forum METALWORK GENERALReplies: 5Last Post: 28th Jan 2016, 04:55 PM -
form tool - interesting video
By steamingbill in forum METALWORK GENERALReplies: 6Last Post: 27th Oct 2014, 09:43 PM -
Home made form tool
By neksmerj in forum METALWORK GENERALReplies: 4Last Post: 2nd Nov 2009, 11:59 PM
