Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    Nov 2017
    Geelong, Australia
    57
    2,672
    Default Herless Surface Grinder - 1987 Model TFY618
    After a rush of blood to the head it seems I'm now the owner of one of these surface grinders.
    Apparently it might be a re-badged Ta Fu Yuan brand (Taiwanese), but other than that I've had a decent search online and not come up with much info on them.
    Anyone have one themselves, or any info on them?
    For starters I'm after any specific info on moving one as I'll be picking it up on Monday. Alternatively any general info/experience about moving small manual surface grinders.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Congratulations!
    Generally speaking, the first thing to check is if the table is sitting on slideways or roller/ball bearings. If the latter, DO NOT transport it with the table in place - remove it.
    Second generalisation is - if it is on slideways, tie it in place somehow, so it can't move about while in transit.
    Thirdly, get it picked up by the base, not the column or any movable protrusions (like the spindle cartridge .
    Many surface grinders and other machine tools have dedicated hooks, lugs, holes or through-holes for lifting bars to pick them up. Look for anything cast in or or bolted on that clearly serves no other purpose - and look for holes near the top of the base that are in line with holes on the opposite side (like back and front).
    Good luck!
    Cheers, Joe
    Nov 2017
    Geelong, Australia
    57
    2,672
    Thanks Joe - great info.
    I don't know whether its on slideways or bearings, and unfortunately got too busy today to call them before they closed. Guess I'll find out on Monday morning when I get there and will just prepare as best I can to be able to remove the table if need be.
    I'll post some decent photos once I've got it.
    Aug 2010
    72
    3,105
    Just in case you can't remove the table at the seller's place - e.g. because of hydraulic cylinder connected or whatever: you could take some strips of timber or aluminium that may allow you to pack up the table a little higher than the roller elements its siting on. That would be an alternative. You would of course have to be more careful about tying the table to the base so it doesn't move in transit.
    Cheers, Joe
    Nov 2017
    Geelong, Australia
    57
    2,672
    Great idea about packing the table up. Is it just the X axis that could be bearings, or possibly also the Y axis too?
    After a fair amount of Googling I finally found a couple of images of this model showing 4 threaded holes on the main casting for attaching eye bolts to lift from, but no way of confirming what size thread from the photo. I'd be guessing 10mm, but I'll take 8, 10 and 12mm ones and slings etc. There's a forklift onsite that can load it for me so hoping it can just be carefully forked onto a pallet, strapped to the pallet for stability, then the whole lot forked on.
    Apr 2012
    Healesville
    2,129
    Steve my J&S has ball bearings on the Y axis and it also has a tapped bolt hole at each end of the slide on each side that you can screw bolts into to lift the whole
    lot up off the balls for transporting.
    Cheers and good luck, shed
    Nov 2017
    Geelong, Australia
    57
    2,672
    The pickup went well. Currently at my work so half way home.
    Table is on slides not balls which made things simpler.
    Its had a conversion to pneumatic X feed in the past. Needs a new on-off valve for that, and some new air lines. You can see the X feed handwheel has been removed as part of the conversion. The head moves up and down smoothly, and I lowered it down gently onto some bits of MDF so that it wasn't bouncing round during the trip home.
    My first thought when I had a close look at the chuck was - "bugger, the handle has been broken off". Thankfully not the case, it just has a removable alley-key style handle.
    Some piccy's as promised:
    Sep 2014
    Sydney
    1
    I have one of these that looks identical however the x- axis on mine definitely runs on ball bearings.
    Nov 2012
    Adelaide
    81
    How did you end up lifting it? Both of mine (different to yours) have holes for bars to go through.
    Aug 2010
    72
    3,105
    It looks like all went well! Congratulations!
    Please remove the wheel from the arbor and 'ring it' (completely free and off the machine - have a look at some youtube videos to find out what it should sound like. You did everything right and your loading and tieing looks great. BUT you cannot exclude someone bumping or hitting the wheel or a pothole shocking it en route. If it doesn't sound clear as a bell, break it in half and use it for deburring! Because surface grinders run so smoothly, their grinding wheels seem totally innocent. However, if one lets go, the shrapnel has enormous inertia and is extremely destructive - especially if it hits someone.
    I've had a small workpiece tip over during grinding once and take a medium chip out of the wheel. No damage done, but I will NEVER let that happen again!!! It was the most frightening event in my workshop - INCLUDING any events where I got injured (never anything more serious than loosing a bit of blood and needing a couple of stitches ).
    That small chunk hitting the spark guard, then the roof then a wall frightened the CR4P out of me!!!
    Cheers, Joe
    Nov 2017
    Geelong, Australia
    57
    2,672
    Quote Originally Posted by smxas View Post
    The pickup involved forklifting it onto a pallet and then onto the ute.
    Getting it off at home wasn't quite as easy. The base has 16mm threaded holes in it for lifting eyes, but the biggest ones I had was 12mm.
    Ended up using a short length of 16mm threaded rod in each hole with a nut either side, and a 1m sling onto the chain block hook. Not ideal but estimating the total weight at around 600-700kg's spread across the 4 points I was comfortable it was going to be OK.
    More of an issue was the height. I only just got it high enough with the hook right up against the chain block and my body weight on the deck of the ute to allow me to get the pallet out.
    Safely back on the ground on a pallet:
    The wheel mounting flanges look like they've had a hard time in the past. There's a pin spanner for the flange but no puller for getting it off the shaft. Guessing I need to make one:
    One-shot oiler:
    The lower protective cover has seen better days:
    Nov 2017
    Geelong, Australia
    57
    2,672
    Stuffed if I can work out how to remove that thumbnail from my last post
    Looks like it was chain driven prior to getting the pneumatic conversion:
    This looks like the end link of the chain was previously pinned to it:
    And maybe an idler pulley used to live here on the LH end of the table??
    Guess I've got to work this mess out...
    Nov 2017
    Geelong, Australia
    57
    2,672
    Thanks Joe. Will definitely test the wheel (once I can get it off!!).
    So far it looks like I'm going to need a fixture, arbor and precision level for balancing - and a tool for removing the wheel from the grinder arbor.
    And a holder for the dressing diamond......
    Nov 2017
    Geelong, Australia
    57
    2,672
    Quote Originally Posted by Jolas777 View Post
    Any chance yours is a chain drive like this one appears to have been? I'm be keen to get some info on how the chain is routed/attached.
    Having never run a surface grinder, I'm thinking I might convert it back to manual for a start while I get used to it, then sort out the pneumatic traverse later.
  15. #15
    Nov 2017
    Geelong, Australia
    57
    2,672
    A question for those of you that have surface grinders - in my situation (ie with this grinder and zero surface grinding experience) would you concentrate on getting the pneumatic traverse working first, or mess about converting it back to a manual cable/chain?
    I'm concerned I might be biting off more than I can chew trying to teach myself the basics of grinding at the same time as getting the pneumatics sorted, but I don't want to invest time in converting it back to manual unless its going to make a big difference to the learning process.
  1. Tool Cutter Grinder - Herless
    By marklr in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 8th Feb 2017, 11:48 AM
  2. Surface grinder.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 12th Jun 2016, 08:13 PM
  3. Replies: 2
    Last Post: 27th Jul 2014, 09:38 PM
  4. Herless Surface Grinding Machine Model - TFY-618
    By Briangoldcoast in forum METALWORK GENERAL
    Last Post: 31st Mar 2014, 11:04 AM
  5. New to Me Herless Surface Grinder
    Last Post: 8th Aug 2011, 02:40 PM
