Results 1 to 15 of 16
Thread: Grinding wheel review
15th Feb 2018, 02:56 AM #1
On PM, someone made a passing remark about 3M Cubitron II grinding disks lasting the longest....
So I did some googling and found some in AUS. https://www.ebay.com.au/itm/252944739652
Pretty expensive I thought, but if they last, then it might be worth the expense for a trial....
I've been using the ONE disk for about 2 months now. Some pretty heavy work (cleaning up plasma severance cut steel plate, cleaning up welding beads etc etc. Giving it a pretty hard time.
The result so far is that it seems to have reduced very little in thickness and NOT AT ALL in diameter. I'm pretty amazed. It seems to cut MUCH faster than cheap grinding disks and with less force applied to the grinder.
Just thought I'd pass that on - only because I'm impressed myself.
Anyone else ever used these?Cheers, Joe
15th Feb 2018, 08:15 AM #2Most Valued Member
No, but now I'm interested!
Thanks Joe.Girl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
15th Feb 2018, 05:48 PM #3Diamond Member
- Aug 2006
- 1,105
Yeah these things are great, I go through one of these every few weeks. They don't clog up like the standard ones do. When they are new you need to be very careful as they can take off more than needed. They are expensive, but work pays for them.
When at home I just use whatever is cheapest as I don't do a lot of grinding here.
If you get a chance try out one of these! https://www.3m.com.au/3M/en_AU/compa...3241514&rt=rud
16th Feb 2018, 01:18 AM #4
I'll try to get some. I also noticed that flap disks are available with the cubitron grains.... ever used those?
Cheers, Joe
16th Feb 2018, 02:31 PM #5Member
- Jul 2012
- Malvern East
- 84
Yes they are exceptional discs and flap wheels wait till you get some linishing belts though they are the next level they never clog up always sharp right till the end
16th Feb 2018, 03:19 PM #6Diamond Member
- Aug 2006
- 1,105
I haven't used a flap disc in about 10 years probably, don't think work even stocks them. I don't really see the benefit in them.
Yeah finishing belts would be a good thing I reckon, wouldn't mind trying some out.
16th Feb 2018, 08:39 PM #7Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Could they be used on toolsteel i.e. hss lathe bits
16th Feb 2018, 09:29 PM #8Cheers, Joe
16th Feb 2018, 10:26 PM #9
Hi Joe, Guys,
I've a number of those 3M disks, that I got a while back. So far I've never used them, I'll have to get them out and have a look at them.Best Regards:
17th Feb 2018, 07:22 AM #10Most Valued Member
- Oct 2007
- 3,112
17th Feb 2018, 01:58 PM #11Diamond Member
- Aug 2006
- 1,105
I just found because of the curved design that it was easy to removal material where not needed. I much prefer an orbital sander and rolocs for finishing type work.
By the way for anyone who hasn't used these things before, they work great for paint and rust removal. 5 x 125MM POLY STRIPPING DISC WHEEL PAINT RUST REMOVAL CLEAN METAL ANGLE GRINDER | eBay
17th Feb 2018, 03:15 PM #12Member: Blue and white apron brigade
- 7,182
17th Feb 2018, 04:02 PM #13Intermediate Member
- Apr 2010
- Warwick QLD
- 53
- 26
I can't say I don't use grinding wheels, they're handy for inside corners & areas where a flap disc would be destroyed; the downside is they can be expensive; lately, I've been using these which aren't too bad...
17th Feb 2018, 08:48 PM #14Most Valued Member
- Oct 2007
- 3,112
I'm not sure what you mean by the curved design? They're round of course, but are either flat or with a bevel on the working face. They do tend to wear roundish, however I've never found that an issue in hitting the correct spot.
I agree, the stripping disks are also good, but I find they don't last as long, and generally aren't as aggressive as a typical flap disk (depending of course on the grit used in each).
17th Feb 2018, 09:21 PM #15Diamond Member
- Aug 2006
- 1,105
The ones I used had a bevel or maybe they were just worn out. I should try some again. Smith & Arrow have some Ceramic ones. https://www.ebay.com.au/itm/5x-125mm...7pUOl01uReh3RA
Grinding wheel
By sossity in forum METALWORK GENERALReplies: 38Last Post: 14th Feb 2017, 06:04 PM -
Grinding Wheel
By Oldneweng in forum METALWORK GENERALReplies: 18Last Post: 15th Jan 2017, 06:07 PM -
Grinding wheel advice
By caskwarrior in forum METALWORK GENERALReplies: 1Last Post: 18th Dec 2016, 08:53 PM -
Which Grinding Wheel For Grinding Tungsten Electrodes
By Metal Head in forum WELDINGReplies: 14Last Post: 8th Aug 2009, 02:23 PM -
Lap grinding wheel
By ROB NZ in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2008, 06:42 AM
