Results 1 to 6 of 6
Thread: Lathe Oilers
    Nov 2016
    37
    18
    Default Lathe Oilers
    Gday all,
    I bought a heerless lathe made in 1989. It has these oiling points imbedded in the castings to lubricate the slides etc. However i'm not sure how inject the oil in them. What oiling gun do these use? And where to get one?
    Sent from my SM-G950F using Tapatalk
    Jan 2016
    Wodonga Vic
    38
    633
    You don't need anything special, just jam the tip of an oil can onto the ball until it depresses and pump in the oil
    Dec 2017
    Tatachilla
    63
    29
    I hate those things, I remove them and tap it for 1/16 bsp and fit a tapered plug. At least I can blow out the hex and not worry about gunk getting pumped in through the action of the oil can.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Bunnings has Kinchrome brand oil cans if you're looking for somewhere easy to buy one. In the tool section and just over $10 from memory with rigid and flexible extensions.
    Nov 2016
    37
    18
    Thanks all. I jammed in the can nozzel and put the oil in. Not a lot gets through but it seems to work.
    Aug 2012
    Greenmount, W.A.
    70
    272
    Model Engineer Workshop (July 2011 Issue 178, page 46) published an oiler for Myford lathes which could be adapted to your problem. It has a central pin that depresses the ball on the oiler, and at the same time opens an internal valve to let the oil flow int the lathe oiler. I made one and it works very well.
    Regards,
    Alan.
  1. Drip oilers
    By morrisman in forum METALWORK PROJECTS
    Last Post: 7th Jul 2016, 09:46 PM
  2. Removing Ball Oilers.
    Last Post: 22nd Jul 2015, 10:15 AM
  3. Drip or wick oilers?
    By Old Hutcho in forum METALWORK GENERAL
    Last Post: 9th Oct 2012, 07:44 PM
  4. spring loaded oilers
    By Stustoys in forum METALWORK GENERAL
    Last Post: 29th Jan 2011, 07:41 PM
