Results 1 to 8 of 8
13th Feb 2018, 08:29 AM #1Golden Member
- Apr 2009
- Kingswood
- 930
Surface Grinder Capstan Wire Rope
My Kent KGS200 uses wire rope wrapped twice around a grooved capstan to connect the travel handle on the saddle to the table for travel.
For a small SG meant for tool room use it works great, so a good fit for hobby use.
The travel is free and smooth today, but yesterday was a drama because the rope was slipping on the capstan.
Much cursing as tried to re-adjust the coils on the capstan and get the tension up so that it cannot do that again.
Very difficult working between the table and saddle - just as well I have small hands !
But, the rope is showing end-of-life.
What do others use for wire rope in this situation ?
Suggestions on a supplier in (western) Sydney.
Suggestions on getting the new rope wrapped around the capstan without removing the table.
John
13th Feb 2018, 08:32 AM #2
For wire rope, in my case, our local bearing and bolt shop carries a range.
Just do it!
Kind regards Rod
13th Feb 2018, 09:20 AM #3Most Valued Member
- 2,672
Boating shops/chandlers usually have a range of stainless wire rope from about about 1mm diam.
What might be a good alternative is one of the synthetic ropes like Dyneema/Spectra. The type with a tight braided cover over the central core rather than the open fully braided style.
They are very hardwearing and don't suffer from bending fatigue around tight radii like wire does (so don't end up with nasty broken strands like wire). Typically plenty of rope choice at a chandlers.
I haven't used the synthetics in a really oily environment, but the couple of leftover lengths from my sailing days that are now used for securing things on the back of the ute. They don't seem to have been affected by general grease/grime from 10+ years of use.
13th Feb 2018, 12:31 PM #4Most Valued Member
- Oct 2007
- 3,112
What is the wire rope diameter?
14th Feb 2018, 08:47 AM #5Golden Member
- Apr 2009
- Kingswood
- 930
Pete,
The rope is 3.34 mm diameter stranded 7 x ( 20 x 0.25 ).
The 20 could be out either way by one, difficult little buggers to hold.
The comparative lack of corrosion makes me think there is some sort of protective coating, but cannot convince myself either way.
My plan is to acquire a length ( 3 m should be heaps ) and sort out how to install, to be kept as a spare.
My rope does not have any broken strands over the working length, the problem is crushing by the clamps at the ends is promoting breakages.
My thread was meant to flush out whether other members have experimented with alternative materials with demonstrated success.
As this rope could very well be original from 1984, a simple identical replacement would work admirably.
John
14th Feb 2018, 09:42 AM #6Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
7 x 19 x 3.2mm ss wire. Should be available at any ship chandlers. 7 x 19 is the most flexible one for going over sheaves.
Alan.
14th Feb 2018, 10:43 PM #7Golden Member
- Dec 2011
- 505
For example ... https://www.whitworths.com.au/wire-3-32-7-x-19-s-s
Bill
15th Feb 2018, 12:55 AM #8Most Valued Member
- Oct 2007
- 3,112
Agreed, any reasonably close SS designed for running should be fine. No need to overthink it
Wire rope cut end finishing options
By prophet in forum METALWORK GENERALReplies: 25Last Post: 26th Jul 2016, 10:28 AM -
Surface grinder.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 12th Jun 2016, 08:13 PM -
Where to get decent quality wire buff wheels for 8" bench grinder in Adelaide
By nearnexus in forum METALWORK GENERALReplies: 31Last Post: 15th Aug 2013, 09:58 AM -
Brazing wire rope?
By grd in forum METALWORK GENERALReplies: 8Last Post: 3rd Apr 2012, 04:51 PM -
Surface grinder
By steptoe in forum METALWORK GENERALReplies: 0Last Post: 10th Jun 2005, 12:21 PM
