Results 16 to 17 of 17
Thread: Shop made metal roller?
11th Feb 2018, 02:00 PM #16
Yes, true. But where is the fun in that? Yours will have MUCH stronger rollers and instead of 1mm capacity, you will have maybe 2mm capacity at full width and the rigidity to do thicker stuff in narrower width. I believe the limits are the gears you end up using. So find some nice LARGE tooth pitch gears with good width - with just the right diameter to fully engage with the rollers down to minimum you want to be able roll, but enough tooth engagement at the thickest you are likely to encounter (maybe 3.2mm). You should have a much better tool than the $400 Chinesium one....
I'll go and take some more photos of mine shortly.
PS: won't get a chance to get to the South Island this time around....Cheers, Joe
11th Feb 2018, 02:12 PM #17Diamond Member
- Aug 2006
- 1,106
Yeah for sure, i'd still have a go at making one and seeing you have all the machinery to do so i'm sure you could come up with something much much better. I'd even go as far as adding a motor to it with a foot controller, wouldn't cost that much extra if you scrounge around.
Sheet metal Roller bearings
By BobL in forum METALWORK GENERALReplies: 9Last Post: 26th Mar 2014, 09:28 AM -
Shop Press Made.
By aametalmaster in forum WELDINGReplies: 26Last Post: 29th Jun 2013, 09:24 PM -
SOLD: New Bead Roller
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 15th Feb 2012, 04:50 PM -
Ring roller anyone made one ?.
By steran50 in forum METALWORK GENERALReplies: 6Last Post: 28th Dec 2008, 11:50 PM -
Sheet Metal Roller
By stevew in forum METALWORK GENERALReplies: 5Last Post: 21st Nov 2006, 10:50 PM
