Results 1 to 15 of 16
6th Feb 2018, 07:19 PM #1Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Electric power feed for Vertical Milling Machine.
Following on from this thread - //metalworkforums.com/f303/t200...hlhaupter-upa4 I am now modifying my old Vertical Mill to allow boring with power down feed. I will be using a 24 volt Planetary Gear Motor with a final rated output speed of 10 RPM.
Measuring the torque required to turn the worm shaft that drives the sliding head down. This allowed me to choose a motor with sufficient torque that will also fit in the limited space available.
Cutting a 3mm keyway in the extended worm shaft.
Tooling used to cut 3mm keyway in 40 tooth gear.
The finished shaft and gear. I am working on the mounts for the motor and will post pictures as things progress.
9th Feb 2018, 03:22 AM #2Golden Member
- Sep 2008
- 838
This is the motor with 19 tooth gear and bracket fitted.
Motor and adaptor plate fitted to machine.
This little speed control seems to work very well giving a full range of speeds from zero to rated motor RPM.
9th Feb 2018, 07:31 AM #3Most Valued Member
- Jul 2016
- 35
- 1,522
Beautiful work Techno, what mill is that, it looks like a TOS to me but hard to be sure, will you still be able to turn the head clockwise with that motor attached?
9th Feb 2018, 09:27 PM #4Golden Member
- Sep 2008
- 838
Can't rotate clockwise unless the motor is removed, CCW is not a problem. The motor is easily removed, just undo 4 screws.
9th Feb 2018, 10:36 PM #5Golden Member
- Sep 2008
- 838
The machine is a German made Biernatzki, from the 1950's I think, I have not seen another one of this model.
12th Feb 2018, 06:38 PM #6Golden Member
- Sep 2008
- 838
I don't have a recent photo of the machine but this is how it looked when I got it in 1991, after some repairs and a new paint job of course. I wish it still looked that good.
It now has 3 axis DRO, Variable speed control via VFD, Electro Pneumatic Power Drawbar and Power Feed for boring.
12th Feb 2018, 07:19 PM #7Most Valued Member
- Jul 2016
- 35
- 1,522
That is a beautiful machine, and a finish to be proud of, how long did that take?
15th Feb 2018, 07:38 PM #8.
- 6,459
Wonderful work as usual Lex.
Serious looking mill too!
Would it be possible to provide details of the motor and its controller? There is an abundance of geared 24 V motors on eBay but most appear to be suitable for low power applications. I have this whimsical idea of copying the table drive used by Dubied on their grinder. It would be great for pretend cylindrical grinding on the Hercus No.1.
Bob
15th Feb 2018, 07:46 PM #9
Hi Bob, Guys,
Looking at your picture, this would be a perfect application for a car window screen wiper motor. Get one from your local scrap yard or car scrapper. I've built a couple of mill table drives using them. To control the speed just vary the voltage feed to them. Car seat and window winders could be pressed into service too.Best Regards:
15th Feb 2018, 08:56 PM #10.
- 6,459
Thanks John,
I had a look on eBay and for around $40 dollars I could acquire a new in the box wiper motor from your neck of the woods. Could prove a better option than something secondhand and doubtful from a local wrecker.
https://www.ebay.com.au/itm/FOR-AUDI...MAAOSwWD1ZtaoE
Bob.
15th Feb 2018, 10:30 PM #11Golden Member
- Sep 2008
- 838
Hi Bob, below is the link to the 50mm diameter motor that I used. It is hard to get reliable information on the torque that these gearmotors can produce, even from the manufacturer, but the one that I am using is going OK although now that I have it all sorted I have realised that I could have gone for the 60mm which would have torque to spare. I have not been able to find any information on the speed control as yet because I can't remember which online store that I got it from.
https://www.ebay.com.au/itm/ZGX50RHH...72.m2749.l2649
16th Feb 2018, 12:38 AM #12
Hi Bob,
All the salvaged wiper motors I have used have been in good condition, maybe a bit dirty on the outside, but having stripped and cleaned them, found little to no wear at all. An advantage is that these usually have two speed motors. A disadvantage if you can call it that is that these motors are designed to run in one direction only. The reason is that when run in the opposite direction, the worm presses against the internal motor bearings instead of the thrust bearing at the other end of the worm. Now I don't see this as an issue since the worm and the motor rotor are on the same shaft and on all the ones that I have disassembled have a thrust bearing at both ends.Best Regards:
16th Feb 2018, 10:40 PM #13
Hi Bob, Guys,
Apologies to Lex for hijacking his thread.
I've found some pictures I took of one of the wiper motors that I stripped and used for a mill table traverse. This one is a "Trico" brand and has a plastic worm wheel driven by a steel worm. The thrust bearing at one end of the worm is a steel ball, adjusted by a screw, the motor end on this one is a steel washer running against a brass or bronze bush that also supports the shaft. The tracks on the plastic worm wheel are the electrical contacts for the delay circuit and are not needed for this application.
I have some more pictures of the unit showing the drive shaft and mountings. If you want to see those let me know.Best Regards:
26th Feb 2018, 09:54 AM #14Most Valued Member
- Healesville
- 2,129
Hi Bob I love the concept but l am wondering about the changing feed speed.
For example at 0 deg of the crank you have 0 ft/min of stroke, as the crank rotates the ft/min of the table increases gradually until it reaches maximun at 90 deg of the crank and then the speed of the stroke will gradually slow to a stop at 180 deg of the crank, then repeat the process in the other direction.
I am thinking that surface finish may be compromized due to a lack of constant surface speed.
Then again am prone to under thinking and over thinking things.
Cheers, shed
3rd Mar 2018, 01:38 AM #15.
- 6,459
Victoria milling machine vertical head
By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 10th Feb 2017, 10:35 PM -
Vertical Milling Machine saved from getting smashed and going to China.
By Burner in forum METALWORK GENERALReplies: 14Last Post: 7th May 2016, 10:49 PM -
ASONG feed box ....... Milling machine
By OldRustyToolie in forum METALWORK GENERALReplies: 9Last Post: 12th Oct 2015, 05:24 PM -
Vertical feed on the Douglas
By Steamwhisperer in forum METALWORK GENERALReplies: 11Last Post: 13th Sep 2013, 12:18 AM -
Douglas Shaper Vertical Feed Repairs
By Anorak Bob in forum METALWORK GENERALReplies: 19Last Post: 5th Apr 2012, 07:52 PM
