Results 1 to 15 of 34
Thread: Table Saw- new part
29th Jan 2018, 03:26 PM #1Most Valued Member
Table Saw- new part
G'day All,
The blade-raising mechanism on my table saw failed a few days ago. The brass nut has worn to the point where it now slips on the male screw. It has a left-handed ½" x 13tpi thread. Weird that it's imperial, because it's made in Sweden and the blade tilt has a 16mm ACME threaded screw.
Anyway, I need to make a new one. It's just a 19.7mm diameter x 125mm long piece of brass. Can anyone suggest what type of brass will best suit this application?
Goliath want $152 for a single tap. I found a few used taps on eBay for reasonable prices, but postage was crazy. What's happened to postage from the UK? They want $30 to post a tap! Postage from the USA has always been expensive, but the UK used to be very cheap for small items.Chris
29th Jan 2018, 04:33 PM #2Most Valued Member
- 4,887
You can get a set of 3 from $37 to $55 including post.
One from Aus $55 or U.K. $37.
29th Jan 2018, 07:35 PM #3Novice
- Albury
- 11
Imperial made in Sweden, that is strange, but I guess anything is possible. 13 tpi is suspiciously close to 2mm thread pitch though?
29th Jan 2018, 07:53 PM #4Most Valued Member
It is close to 2mm, but I checked and the 13tpi gauge is a perfect fit. The 2mm is close, but no cigar.
29th Jan 2018, 10:24 PM #5Most Valued Member
30th Jan 2018, 08:36 AM #6Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
For what it is do you need to stay with an ACME thread or even brass/bronze? To get up and running again while you are sourcing taps and brass, cobble a temporary fix using 12mm threaded rod and 20mm bright round, keep telling yourself it is only a temporary fix.
Repeat in a year or 4 when temporary fix wears out.
30th Jan 2018, 09:06 AM #7Most Valued Member
Table Saw- new part
G’day Bob. The part in question is for the blade raising mechanism and is UNC. The ACME thread is on the blade TILT. I only mentioned it to highlight the mixture of metric and imperial. Sorry for the confusion.
While your fix would work it would mean having to rotate the raising handle anti-clockwise to raise the blade. After 27 years of rotating the handle clockwise that would do my head in.
Sent from my iPhone using TapatalkChris
30th Jan 2018, 09:29 AM #8
Bob Ward has already hinted at this suggested fix.
Would a LH thread close to the pitch of 13TPI and availble in Australia be a substitution ? Would 0.25mm diference in pitch be a deal breaker?
Theres is a LH 12mm x 1.75 HSS TAP and DIE on ebay for $38 odd free post.
https://www.ebay.com.au/itm/M12-X-1-...UAAOSwmrlUrv07
and a M12 x 1.75 x 1 Metre Mild Steel Allthreaded Rod Left Hand Plain $38 odd at Bolts and Industrial Supplies.
30th Jan 2018, 11:30 AM #9Most Valued Member
Good question Grahame. I don't know.
I have found 1" PB1 bronze locally (George White Metals) for $140/m and they will sell me a short piece. I also found a set of three LH ½" x 13 UNC taps for $55 from LPR Toolmakers. I really only need one, but I can't source a single tap in Oz and postage from OS is prohibitive.
To clarify, here's a pic of the male threaded part.
Edit: correct bronze price.Chris
30th Jan 2018, 12:04 PM #10Golden Member
- Cairns, Q
- 666
FWIW that would be my choice, not that I have any special knowledge of the subject. However, if brass is much cheaper, it is probably worth redoing it in brass as a "temporary" measure, since you got 27 years out of the original! Will you still be around in 2045 if you have to replace it again, or will it be someone else's problem?
If it were me I would prefer to keep all sizes standard if possible
Check LPR as a source for L H 1/2" UNC taps. He has carbon steel ones in the catalogue for $46.80 a set. Don't know whether he stocks individual taps in this size - it might be worth asking.
Frank.
Added later: Chris, your last post came up while I was typing this.
30th Jan 2018, 12:12 PM #11Most Valued Member
Table Saw- new part
Hi Frank. I hope to be around then, but I doubt I’ll still be woodworking! You make a good point about how long the original brass one lasted. In fact, it lasted 34 years. I’m the second owner of the machine.
I contacted LPR and he only sells the LH taps in sets.
30th Jan 2018, 12:31 PM #12Most Valued Member
- 4,887
If its not urgent get the UK ones.
30th Jan 2018, 12:39 PM #13Most Valued Member
Can you post a link please Peter? The only one I found in the UK was a used Dormer for $26 plus $30 postage.
30th Jan 2018, 02:24 PM #14Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
These guys will sell you a 12 x 1.75 LH carbon steel tap for $6.76 posted and the matching die for $5.63 posted. I've used them in the past without disappointment, I have a 3/4" x 10 LH tap and die on the way at the moment, the post can take 2 to 4 weeks.
https://www.aliexpress.com/store/pro...53c80f91e9QE2E
30th Jan 2018, 02:33 PM #15Most Valued Member
- 4,887
Don't know how to do the link, search RDG 1/2unc l/h.
Casting Tools Part 5 - Casting a part
By RayG in forum THE FOUNDRYReplies: 10Last Post: 30th Jul 2018, 12:46 PM -
Box tubing clamp for holding table leg to table frame
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 11th Jan 2017, 12:05 PM -
FixturePoint Welding Table 900 x 600mm Table
By dradyz in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th May 2016, 01:38 PM -
New Lathe Part 2
By Oldneweng in forum METALWORK GENERALReplies: 121Last Post: 28th Mar 2016, 09:05 PM -
Screwcutting part 2
By Kody in forum METALWORK GENERALReplies: 7Last Post: 8th Jan 2009, 12:22 AM
