Results 1 to 11 of 11
17th Jan 2018, 10:04 PM #1Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 225
Algra Rapidue Quick Change Tool Post.
Hi everyone, I have one of these tool posts, its a type A and I need some more tool holders. I can get genuine ones for a lot of $$$ and there are Indian and Chinese copies on evilbay which seem to be slightly different dimensions. Has anyone got a detailed plan of the holders and/or has anyone made their own? I have searched the archive's here and the web to death and can't find any dimensioned drawings.
I probably could make my own, but by the time I sourced the material, buy the necessary tooling and then I have no way to harden them, so I would have to send them away and freight is a killer up here.
Would I be better off cutting my losses and buy a whole new style of QCTP with cheaper spare holders?
All help appreciated as usual.
Rgds,
Crocy.
17th Jan 2018, 10:30 PM #2
Hi Crocy,
From the PDF they look to be quite specialised, expensive ! Getting Asian copies might be the way to go if the mounting faces are accurately made, the tool holding faces are less critical. I would be tempted by a copy but only if the price is much less, on the basis that I would throw it away if it was a bad fit, and go for a more common and probably less costly QCTH.Best Regards:
18th Jan 2018, 06:44 AM #3Philomath in training
- 6,541
The Aloris style holder is probably the simplest to make, and I recommend that style of QCTP primarily for that reason (given that all these different types all 'QC' and are all 'TP's')
I guess the decision is how much will it cost you. Those holders look similar to the Dickson type QCTP which is probably why you are getting so many similar holders which are not quite the same.
You mentioned hardening though. While in a commercial shop that may be an advantage, in a home situation you can probably get away without it. I've made holders without hardening and they seem to last. I bought some holders from Shars many years back and they were not hardened and worked fine.
18th Jan 2018, 04:37 PM #4Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
All the dimensions are here: http://algra.it/wp-content/uploads/A...e-toolpost.pdf
18th Jan 2018, 10:54 PM #5Senior Member
- Jun 2005
- 225
19th Jan 2018, 09:42 AM #6Senior Member
- Dec 2010
- Syd
- 492
Looks like what is termed an "Italian multifix" by Create tools and the numbering system seems to match, if you didn't want to DIY. Quality of their stuff in the usual 40 position stuff is/was good, despite the country of origin.
19th Jan 2018, 05:32 PM #7Pink 10EE owner
- 6,216
DaveJ a local that used to post here built a lot of those type of holders and posted about it here -->> Making quick change tool post holders (picture heavy)
19th Jan 2018, 09:59 PM #8Senior Member
- Jun 2005
- 225
Thanks for that Hunch, I will enquire for a price from them. The main reason I want to stay with the Algra QCTP is that I can keep 3 different tools on it at the same time. Most of the others are single or 2 only.
Thanks for that link RC. That was a very good tutorial. I just have to see what material I can buy, I probably want another 6 or so.
Rgds,
Crocy
I have said this before, but I really do appreciate the extent some members of this forum go to to help us part timers.
7th Mar 2018, 11:00 AM #9Senior Member
- Aug 2013
- 229
Here’s a YouTube video on making some holders
https://youtu.be/xmfw1phGV90
7th Mar 2018, 08:27 PM #10.
- 6,458
8th Mar 2018, 07:50 AM #11Golden Member
- Apr 2009
- Kingswood
- 930
I had an Algra on my Bantam lathe but I found they had a weakness in the linkages that applied the pull force to the holder.
I replaced the really bad linkage and got some spares, and then passed on the Algra with the lathe when it was sold.
I purchased an Aloris clone for my current M250 as additional holders are much easier to manufacture.
I did find, however, that the adjustment fixings on the Algra were more convenient then the Aloris clone.
John
Quick change tool post
By TKO in forum METALWORK GENERALReplies: 5Last Post: 20th Oct 2013, 10:15 PM -
Algra Rapidue Tipo M QCTP Opinions
By Briangoldcoast in forum METALWORK GENERALReplies: 11Last Post: 11th Sep 2013, 09:21 AM -
quick change tool post help
By Aerohydro in forum METALWORK GENERALReplies: 5Last Post: 23rd Apr 2012, 12:11 AM -
By scratchbuilt in forum METALWORK GENERALReplies: 18Last Post: 13th Mar 2012, 07:46 PM -
By tinkera in forum METALWORK GENERALReplies: 3Last Post: 22nd Sep 2010, 11:17 AM
