Results 1 to 8 of 8
2nd Jan 2018, 11:12 PM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Snap rings, circlips, snap ring pliers
I'm working on a Toyota gearbox at the moment and there are several external retaining rings of this style (the large one is 75mm) holding gears and bearings in place. The Toyota gearbox manual calls them snap rings rather than circlips and also refers to snap ring pliers to remove and replace said snap rings.
I'd like to find the proper pliers for these snap rings, even if its only to satisfy my curiosity as to what they look like, ATM I'm using standard circlip pliers, ordinary pliers, screw drivers but its slow and fiddlely and a right PITA.
My google foo must be weak, try as I might all I can find on the net is standard circlip pliers, i.e. the ones designed to work with the retaining rings with the holes in them. Anyone have any thoughts?
2nd Jan 2018, 11:38 PM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
3rd Jan 2018, 12:31 AM #3Most Valued Member
- 5,942
Hi Bob, found what you're looking for, here's the link to the picture. I have a pair that I can express post, to you if you can't get hold of a set, PM me if you would like me to post them up, you would have them Friday
I typed in flat blade circlip pliers.
I tried to find one in Repco, and several other sites, to no avail, You might have to make or modify a tool otherwisw
| BAHCO
https://www.ebay.com.au/itm/Circlip-...gAAOSwstJZXNDr
Regards,
3rd Jan 2018, 06:51 AM #4Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
So the secret (to me) words are "flat tip" - that works a treat, thanks guys. Thanks for the kind offer Kryn, I've ordered a pair from your eBay link.
3rd Jan 2018, 08:11 AM #5Pink 10EE owner
- 6,216
Kinchrome call them "flag tip"
https://www.kincrome.com.au/circlip-plier-flagged-tipGold, the colour of choice for the discerning person.
3rd Jan 2018, 12:08 PM #6Most Valued Member
- 2,651
Using the correct tool is always best, but in the past I've modified a couple of smaller (~30mm diam) circlips by drilling small holes near each end for standard style circlip pliers. I was surprised that they drilled quite well just with a good HSS bit
From memory I had looked at replacing the circlips with standard ones, but found the standard ones were a lot thicker so wasn't an option. Application was on idler pulley bearings that I needed to be able to replace in the field.
3rd Jan 2018, 01:25 PM #7Mechanical Butcher
- Oct 2004
- 1,894
At a pinch, I'd be inclined to try modifying a pair of normal circlip pliers with a bit of blacksmithing.
3rd Jan 2018, 05:44 PM #8Most Valued Member
- 5,942
You're welcome Bob.
Nice idea Jordan, but it think you'll find that they're too light a duty to do that too. The circlips Bob's refering to are about twice possibly three times the thickness of normal pinned types.
BSP Cap Screw Gauges x 2 (Go/No go gauges - Snap Gauges) FREE
By John T K in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 1st Oct 2017, 01:20 PM -
Lever locking pliers - slide hammer adapter
By nearnexus in forum METALWORK GENERALReplies: 2Last Post: 8th Dec 2012, 08:00 AM -
Top Quality MIG Welding Pliers
By Jarh73 in forum WELDINGReplies: 11Last Post: 27th Feb 2012, 12:24 PM -
Tools / techniques for snap rings?
By Bryan in forum METALWORK GENERALReplies: 8Last Post: 25th Aug 2011, 10:08 PM
