Results 1 to 13 of 13
28th Dec 2017, 05:00 PM #1Intermediate Member
- Apr 2016
- Australia
- 27
Brass shim stock - natural, what is it?
Hi All.
Anyone know what "natural" brass is vs the "standard" yellow stuff? Is it literally just the finish or something else? Suitable enough for shim stock?
https://uk.rs-online.com/web/p/shim-kits/0681249/
28th Dec 2017, 05:05 PM #2China
- Dec 2005
- South Australia
- 1,658
My guess would be that is has no surface treatment or finish.
28th Dec 2017, 06:06 PM #3Intermediate Member
- Apr 2016
- Australia
- 27
28th Dec 2017, 10:00 PM #4
Whats wrong with using the normal stuff ?
It seems expensive once you get it posted here.
29th Dec 2017, 12:07 AM #5Intermediate Member
- Apr 2016
- Australia
- 27
29th Dec 2017, 12:18 AM #6Most Valued Member
- Oct 2007
- 3,112
I agree with Grahame, that seems a bit pricey to me. I bought a pack of various shim stock from Enco when they used to post to Australia, and it wasn't especially expensive. What exactly are you using it for and does it need to be brass?
I think ebay is your friend these days, and I'd be surprised if you couldn't get something much cheaper than that. What I also use are large feeler gauges and just break open the set. Some sets are large enough for shimming, and they're available for peanuts from the usual suspects. Even the cheapest are remarkably accurate from my experience, but I may have just got lucky. Good enough for shimming in any case.
29th Dec 2017, 07:05 AM #7Philomath in training
Shim stock is the sort of thing that accumulates so if you can say how much you need (and where you are) you may find someone has a small piece that they can spare. Typically the minimum amount that you can buy and the amount you need never matches very well...
29th Dec 2017, 07:30 AM #8
I found this in a few moments.
https://www.ebay.com.au/itm/Shim-Bra...75.c100623.m-1
That 6 assorted brass shims for &19 plus a $9 ship charge.
Not real bad given you can load the box with other desirable engineering items from the same site.
The natural brass could be I suspect a lower copper alloy that is used in decorative drawer pulls and the like with lower tarnishing properties. There are lots of sites that I found that mentioned as "natural brass". Why and where it applies in the context of shim I can't say.
29th Dec 2017, 02:45 PM #9Intermediate Member
- Apr 2016
- Australia
- 27
Thanks for all of the comments.
Haha... It's nice how we can "clean up" seemingly brash posts on this site after submitting isn't it? I've looked at those packs on eBay in the past, seems okay for an assortment pack. I didn't buy them in the past as I needed to go down to 0.001" at the time.
Yeah, agree - I already have quite a bit but not enough in the size I need (300mm length x 0.38mm thick). I need them as one piece rather than laminating for reasons I won't delve into. I should have been clearer on that but was more of an interest thread to see if anyone knew what "natural" brass was. I'm sorted (I think) found a local supplier that has the size I want - just have to wait for them to come back from holidays next week rather than purchasing an assortment pack
As mentioned that website was only an example of "natural" brass. Some sites have this "natural" comparatively cheaper that than the other types they have which is why I was wondering it's make up. Unfortunately eBay (AU) just doesn't have the size I want, don't want to wait for an overseas order...
I've done that in the past, they just aren't a large enough area for what I want at the moment.
29th Dec 2017, 03:11 PM #10Pink 10EE owner
- 6,218
Not sure how any brass can be "natural" It does not as far as I know occur in nature.
29th Dec 2017, 09:45 PM #11
I suspect that "Natural" refers to the colour and lack of heat treatment to anneal the brass, i.e. it is left in the work hardened state as it would be after rolling.
I recall from way back, that brass shimming used to fill an uneven gap, had to be softened so that it would give / flow into a void between surfaces, rather than a hard packing as used to adjust clearances.
Changing the subject a little, there has been about 100 mm of snow here with ice underneath it.Best Regards:
30th Dec 2017, 12:08 AM #12Most Valued Member
Hi Baron, The only thing I can say about that is BRRRRRRRRRRRRR. That's cold.
30th Dec 2017, 06:28 AM #13
Hi Kryn,
Yes it is ! The temperature dropped to minus twelve centigrade last night and it's down to minus four at the moment (19:20h) here. Yet the weather forecast for tomorrow is 8 to 10 degrees C, along with flood warnings.Best Regards:
Building a natural gas forge - WIP
By BobL in forum THE SMITHYReplies: 48Last Post: 27th Nov 2015, 09:17 PM -
shim stock or gauge plate supplier
By .RC. in forum METALWORK GENERALReplies: 24Last Post: 12th Mar 2014, 05:46 PM -
shim stock
By welder in forum METALWORK GENERALReplies: 3Last Post: 6th Sep 2013, 10:23 AM -
Does anyone need any spring steel shim?
By Michael G in forum METALWORK GENERALReplies: 7Last Post: 19th May 2013, 03:18 PM -
shim stock
By alfawolf in forum METALWORK GENERALReplies: 3Last Post: 11th Sep 2006, 05:48 PM
