Results 1 to 10 of 10
Thread: Please help id unusual lathe
23rd Dec 2017, 08:51 PM #1Senior Member
- May 2010
- 135
G'day,
Hopefully this all comes through ok.
The photos are of an unusual lathe i am trying to help the owner identify.
The chuck is about 5 inches across (125mm), and the distance between centers is about 24 inches (600mm).
What is so unusual, to me, is that the carriage is not connected to any form of rack or leadscrew, but instead is moved manually to a point along the bed, and locked in place via the red knob from underneath. The tool holder is then moved through a limited range on motion via the slides on the carriage.
The only nameplate is from McPhersons, who i believe were sellers, not manufacturers.
Do you know about this style of lathe?
What is it?
Why the odd carriage setup?
Des
Sent from my SM-N910G using Tapatalk
23rd Dec 2017, 10:05 PM #2Pink 10EE owner
- 6,218
It would be a manufacturing lathe of some sort.
The Hardinge DV59 came in the same configuration. eg: https://www.ebay.com/itm/Hardinge-DV...-/232281234821Gold, the colour of choice for the discerning person.
24th Dec 2017, 07:42 AM #3Senior Member
- May 2015
- Richmond
- 214
Rivett 505, 507 & 606 lathes
Looks like a basic Rivett lathe for small toolroom work.
24th Dec 2017, 09:33 AM #4Senior Member
- May 2010
- 135
Thanks Rusty, that is a good match to what I saw.
The guy bought it to learn machining, but was perplexed to why it was different from everyone elses lathe. Now he can decide if he keeps it, or goes and gets a basic "normal " lathe with full lead screw and carriage travel.
Des
24th Dec 2017, 09:51 AM #5Banned
- Feb 2015
- Oz
- 73
- 459
I like the tool post, unusual! I take it the carriage is locked in place on the bed and only the cross slide and compound? slide are used? I've only ever seen that setup on very small watchmakers lathes.
24th Dec 2017, 12:53 PM #6Senior Member
- May 2015
- Richmond
- 214
The dead give away is the toolpost on Rivett lathes Des. Eveleigh Loco Works Toolroom had two of the 608?? precision lathes which I had the pleasure of using during the 1960s. An absolute dream to use on fiddly things. I often wonder what happened to them when the depot closed. They had the full set of accessories with them back then.
24th Dec 2017, 12:54 PM #7Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Nothing stamped on the back of the chip tray or bed?
24th Dec 2017, 01:52 PM #8Most Valued Member
- Jul 2016
- 35
- 1,522
It certainly looks well made and very poorly painted, although in seasonally appropriate colours, is this going to join your shed stable?
24th Dec 2017, 05:27 PM #9Senior Member
- May 2010
- 135
Caskwarrior,
It's not mine, just belongs to a friend of my parents. My stable is full, heavily modified Taig lathe, and a southbend 13b..
Even after the shed is built, I will have to be cautious about accumulating too many tools (who can believe this as a problem? )
Des
25th Dec 2017, 02:20 PM #10Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Unusual tool - what is it?
By Alf Scotting in forum METALWORK GENERALReplies: 4Last Post: 7th Oct 2017, 11:42 AM -
An unusual later model Hercus lathe
By kwijibo99 in forum THE HERCUS AREAReplies: 3Last Post: 23rd Jun 2016, 12:50 PM -
Unusual problem with Steelmaster 12 x 36 lathe
By Grahame Collins in forum METALWORK GENERALReplies: 23Last Post: 15th Jan 2016, 10:22 PM -
Unusual Lathe Backplate
By electrosteam in forum METALWORK GENERALReplies: 5Last Post: 26th Jan 2015, 08:46 PM -
De-rusting an Unusual BBQ
By pwaite in forum METALWORK GENERALReplies: 8Last Post: 18th Feb 2007, 01:28 PM
