Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    6,481
    Good Morning Steve,
    I originally thought that you were referring to the "T" slots in the press drill table where they go right through like the ones on my Fobco Star.
    Like others have said plates that run in the slot and full "T" nuts are my preferred method of securing things to the table. I tend to use hex bolts and washers or stud bar cut to suit, simply because with things like jigs, vices and the like, they tend to be things that you use repeatedly. So the fastenings are kept with those items. I have a couple of plates with a pair of tapped holes and short bolts in them, reserved just for one particular drill vice which also has a pair of locating pegs screwed into the base. Useful on the XY table that is secured to the drill press base.
  2. #17
    6,481
    Default Hardware !
    Here you are Rodm, though I'm sure you have seen mounting and fastening hardware before.
  3. #18
    Sep 2006
    Australind , WA
    58
    1,281
    I decided to make some T Nuts out of Delrin on my CNC Machine.I can't imagine having to tighten them that much that I will distort or damage them. We will see.I can just use M12 bolts now. Got some very thick washers of Ebay and some flange nuts.Should work fine.Had minor incident where the material moved just after the first cut ( right side. )Another clamp stopped it happening again....Steve
  4. #19
    Jun 2016
    Sydney
    283
    DELRIN??? For a T-nut ????
    um ... I didn't think of that. It's rather clever.
    The Delrin is in compression between the bolt head and the T-slot rather than in shear along the threads.
    Clever.
    Roger
  5. #20
    Sep 2006
    Australind , WA
    58
    1,281
    Yep....Hope it works OK. lol
  6. #21
    6,481
    Hi Steve,
    Interesting application for a plastic, I've seen many sizes and styles of nut using injection moulded plastic ! It does occur to me that these "T" nuts could be also be 3D printed, and as Roger says, the plastic material is in compression, so the only question would be, how much a particular plastic would creep under load.
    Now who has a 3D printer and is game to test this one out ?
  1. 12mm plate with small MIG?
    By brendanh in forum WELDING
    Last Post: 22nd Mar 2015, 05:24 PM
  2. HIGH TENSILE BOLTS Vs MILD BOLTS.
    By chambezio in forum METALWORK GENERAL
    Last Post: 3rd Jan 2014, 08:25 PM
  3. bending 12mm steel rod
    By 2zenmonks in forum METALWORK GENERAL
    Last Post: 22nd Feb 2012, 09:21 PM
  4. Drilling 12mm holes in 8mm gal steel
    By slamdunk in forum METALWORK GENERAL
    Last Post: 11th Feb 2012, 06:55 AM
  5. Shaft size for 12mm bearing?
    By warren in forum METALWORK GENERAL
    Last Post: 15th Apr 2007, 11:45 AM
