Results 1 to 4 of 4
Thread: BS-5 Bandsaw table
10th Dec 2017, 06:21 PM #1
BS-5 Bandsaw table
In another thread Electrosteam made mention about his BS-5 bandsaw.
A few years back Rob (Nearnexus) posted some information about a better table for the BS-4 -Basically it is the generic Rong Fu base model.
We were on a bit of a bandsaw mods series of threads at the time and I have used some of the ideas and have pics of others.
The trick was to chuck the old sheet metal table and make a small table out of 5-6mm aluminium plate which did not need removal/replacement but neatly fitted into the deck base profile when in the horizontal mode.
Hoping to be helpful I have posted some pictures and diagram below of that and variations which I believe may be useful to you and perhaps other members.
Of course the table was made for the BS-4 and not the BS-5 but I believe it would take little modification to make it fit.
The diagram shown is just there to give an idea on hole centers and you need to do a bit of cardboard template work to achieve the fit in closed (down) position.
Believe it or not the table while appearing small, works very well once the operator gets used to it. Behind the Multitool linisher the bandsaw is now the next most used power tool in the shed.
10th Dec 2017, 06:34 PM #2Banned
- Feb 2015
- Oz
- 73
- 459
I assume you mean the BS-5S as there is also a BS%v now. The BS5S comes with a largish table but the saw can't be used horizontally with the table on, a bummer; however, the cut out as depicted is a good idea, I'll see if I can use this idea on mine as I quite often use it vertically.
I was in Hafco Melbourne a week or so ago and had a look at the BS-5V, looks quite well made for a portable, cast iron base rather than a sheet metal base.
https://www.machineryhouse.com.au/Ar...utting-Bandsaw
10th Dec 2017, 07:32 PM #3
Oops,
I wasn't helpful at all then.
I didn't check the BS-5 was a swivel job then.
Sorry about that guys.
10th Dec 2017, 09:58 PM #4Banned
- Feb 2015
- Oz
- 73
- 459
I wouldn't say that, I never use the table because with the table on the saw can't be used in the horizontal, your plate with the cutout makes it possible. Put your mind to work and come up with an adjustable table; unfortunately, the tables on bandsaws don't sit square with the blade. Another one of those jobs I've never got around to.
Box tubing clamp for holding table leg to table frame
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 11th Jan 2017, 12:05 PM -
FixturePoint Welding Table 900 x 600mm Table
By dradyz in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th May 2016, 01:38 PM -
Bandsaw Extension Table
By Oldneweng in forum METALWORK PROJECTSReplies: 10Last Post: 6th Jan 2016, 01:56 PM -
Which Bandsaw?
By tongleh in forum METALWORK GENERALReplies: 18Last Post: 20th Nov 2012, 04:05 AM -
Bandsaw Table Insert
By Woodlee in forum METALWORK GENERALReplies: 10Last Post: 28th Jul 2008, 10:20 PM
