Results 1 to 12 of 12
7th Dec 2017, 11:21 PM #1Senior Member
- Mar 2017
- Brisbane
- 245
7th Dec 2017, 11:42 PM #2
You might try an electrical repair place or a household appliance spare parts store.
Wife worked at an electrical tool repairers and they had a large range of brushes on the shelf and could often match brushes to the customer samples.
8th Dec 2017, 07:26 AM #3
Hi,
Whenever I get stuck like this I get brushes that are of a size that I can sand down to suit and then use the original springs if they are not damaged. I know some brushes have tails in them ! These are easy to make with a little care drilling a suitable hole and pressing a ferrule crimped onto the braid into the hole. For small brushes 6 or 8 mm cross section I don't bother, preferring to rely on the spring pressure.
HTH.Best Regards:
8th Dec 2017, 08:01 AM #4Senior Member
- Mar 2017
- Brisbane
- 245
Thanks, where's a good place to buy brushes?
8th Dec 2017, 09:15 AM #5Most Valued Member
- Jun 2012
- SA
- 1,649
The worst that can happen is you will fail.
But at least you tried.
8th Dec 2017, 05:54 PM #6Senior Member
- Mar 2017
- Brisbane
- 245
I can't find any big enough! I've scrolled through 100 on ebay. The dimensions are 19.5mm x 9.5mm x 22mm(long). Driving me mad!
8th Dec 2017, 08:10 PM #7Most Valued Member
- Jun 2012
- SA
- 1,649
8th Dec 2017, 08:22 PM #8Member
- Sep 2015
- 62
8th Dec 2017, 08:27 PM #9Most Valued Member
- 2,666
Try Ashdown Ingram auto electrical supplies. I've found them very good the times I've been chasing brushes for vehicle starter motors and alternators.
I've always just gone into one of the stores with the parts I'm trying to match, but if its just brushes they may be able to match the dimensions over the phone.
8th Dec 2017, 08:35 PM #10Senior Member
- Sep 2008
- texas, queensland
- 248
dealt with this mob for years all through the 60s 70s and 80s . if they dont have brushes to suit i will be amazed .
https://www.achargreaves.com.au/
johno'If the enemy is in range, so are you.'
8th Dec 2017, 09:05 PM #11Senior Member
- Mar 2017
- Brisbane
- 245
Thanks for the link texx. Yeah I need em within a week or so.
10th Dec 2017, 12:58 AM #12
Hi j3dprints,
I would buy these and not worry about them being slightly longer ! Half a millimetre off the sides is just a few rubs on some 120 grit sandpaper. Messy dust but hardly a big problem.
Another thing that I have done is rescued brushes from old generators in the scrap yard and sawn and filed them down to fit. I have some that are nearly 2 inches long, quite well worn at that. They are about half an inch thick and a little over an inch wide. In fact at the moment I'm using a pair cut from one of these salvaged brushes on my BF20 mill motor. The machinery dealers want an arm and both legs for a pair over here.Best Regards:
GMC 2200W friction cut off saw - Brushes
By Grahame Collins in forum METALWORK GENERALReplies: 18Last Post: 22nd Jun 2017, 07:25 PM -
Collet chuck.unknown use.
By azzrock in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 15th Mar 2017, 07:58 PM -
Electric Furnace ... unknown control
By Vernonv in forum THE FOUNDRYReplies: 9Last Post: 15th Mar 2016, 06:52 PM -
Unknown brazing rods
By phelum in forum WELDINGReplies: 0Last Post: 4th Apr 2012, 07:24 PM -
Unknown Tool Steel
By RayG in forum METALWORK GENERALReplies: 23Last Post: 26th Sep 2011, 10:34 PM
