Results 1 to 15 of 22
Thread: 'B' Section Link Belts
21st Nov 2017, 09:48 PM #1Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Are they as good as the marketing claims and does anybody know where to find them at a decent price?
I'm getting a lot of vibration from the stiff old headstock drive belt on my lathe, it's time to replace it and I don't really want to pull the lathe apart if I can avoid it.
Ben
21st Nov 2017, 09:57 PM #2Senior Member
- Feb 2016
- NSW
- 117
Never had a problem with link belts, and they're certainly worth pursuing for final drive on a lathe to save pulling the spindle. Quality link belt is however sickeningly expensive. An available local source of B section link belt is Blackwoods (P/N 09858017), but it's $150 a meter. Can be had a lot cheaper from overseas if you look.
21st Nov 2017, 10:23 PM #3Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Ouch..$150 per metre, looks like the spindle's coming out
Thanks though.
21st Nov 2017, 10:39 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
I have bought leather b section link belt from greys industrial supplies in Collingwood melbourne for about 50 pm, nice guys too although they only carry really old stock, its leather.
21st Nov 2017, 10:50 PM #5Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Thanks for the lead caskwarrior, I'm traveling over that way early next year, will look into it.
Edit: I've added a link to G & R Industrial Products to assist anyone else looking for leather link belt
Melbourne's leading industrial products supplier | G & R Industrial Products | castors pulleysLast edited by NedsHead; 21st Nov 2017 at 11:00 PM. Reason: added a link
22nd Nov 2017, 05:35 PM #6Golden Member
- Dec 2007
- 574
The stuff's not cheap here for some reason don't know why so I have ordered some of this from the UK
https://www.ebay.com.au/itm/Megadyne...VQeaPjjUoE0LYA
A 1 metre length 36 UK Pounds or approx $AU64 inc shipping. The Nut-link or Brammer type which has the rivets in it is also available for a similar price but I have heard the Power Twist type is better.
23rd Nov 2017, 08:45 AM #7Most Valued Member
- Charlestown NSW
- 1,669
Its called the "Australia Tax". Non Government and Unofficial.
I was recently looking for something and found it on the RS components UK site. The price over there was equal to about $9 aus. The exact same part (the only thing different on the webpage was the location and price) from RS components in Australia was over $22 + gst. This was on something made in china so they probably couldn't use the "its so far to transport to Australia" argument.
I'm sure just about everyone here could relate a similar story.
peter
7th Dec 2017, 10:30 PM #8Golden Member
- Dec 2007
- 574
My linked belt arrived today, took all of around 5 min to install - old belt cam off with a sharp knife. Not sure what the new belt is made of but it is quite stiff, once sized I had a few links left over. The lathe does not run quieter but it is smoother, I had a couple of bad vibrations that used to shake the worklight, I worked out the approx revs this happened and just avoided them. The old vibration has gone but I have noticed a new vibration at different revs, however it is so slight it barely moves the worklight. 20171207_210142.jpg20171207_210122.jpg
15th Mar 2018, 08:45 PM #9Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I finally picked up some link belt to replace the old, worn out vee belt driving my lathes spindle, I didn't consider that there wouldn't be enough clearance between the large pulley and the casting to slip the new belt on, bugger!
I think I'll just scrape the casting until there's enough room to slip the belt into position.
Does anybody have an example of a scraper made from a file I can copy? I need to know what shape to grind, bevel angle etc
Thanks,
Ben
16th Mar 2018, 03:04 AM #10Most Valued Member
- 4,887
Looking at your photo there appears to be quite a bit of material that needs to be removed for clearance, have you consider using a rotary bur for material removal.
16th Mar 2018, 10:06 AM #11Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Yeah pipeclay, there's a bit of material to remove but I don't have a rotary burr and my air compressor is too small to supply air to my die grinder (and it's too bulky to reach anyway)
I thought if I take my time scraping I would eventually get there
16th Mar 2018, 11:18 AM #12Most Valued Member
- 4,887
You Could use an electric drill.
16th Mar 2018, 06:01 PM #13Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
By the time you remove enough metal to clear the belt you'd almost be through to the other side anyway, why not just drill two large holes and cut out the aluminium between with a jig saw. At least it might look reasonable.
What lathe is that? Same setup as the AL-300 under the hood.
16th Mar 2018, 08:11 PM #14Most Valued Member
- Charlestown NSW
- 1,669
Why not just bite the bullet, pull the spindle out, and fit a new proper belt? Its not such a big or difficult job. I did mine some time ago now. Cant remember how long it took but I can't remember there being any real dramas.
peter
16th Mar 2018, 08:24 PM #15Golden Member
- Oct 2001
- ACT
- 667
its a link belt, cant you just decouple it. feed the end down around the pulley, and join it again further around?
Linked V belts
By Swarfmaker1 in forum THE HERCUS AREAReplies: 11Last Post: 22nd Jan 2016, 06:59 PM -
Cogged belts - again
By eskimo in forum METALWORK GENERALReplies: 3Last Post: 27th Aug 2014, 11:09 AM -
Flat Belts
By Fossil in forum METALWORK GENERALReplies: 11Last Post: 8th Jun 2008, 10:08 PM -
Link belts
By warren in forum METALWORK GENERALReplies: 13Last Post: 23rd Mar 2007, 10:09 PM
