Results 16 to 30 of 33
28th Nov 2017, 08:28 PM #16Most Valued Member
- Oct 2007
- 3,112
I've never had to sharpen mine, so couldn't say what the angle should be. I'd say the Elora is less than 60 degrees however, more like 30-40. I'll try to measure it when I can. Unlike a centre punch, there's no hard and fast figure for this as far as I'm aware.
There's no black magic involved in any of this, merely the ability to drill and ream a hole in "something" and have a punch and clear perspex rod of the same diameter slide within it. Turning a centre is a complete no-brainer and I'd suggest the most difficult part is to scribe two lines on the perspex that are precisely in the centre, approximately at right angles, and has a magnifying shape polished at the opposite end. It should all be quite straight forward lathe work with a tool set to accurate centre.
28th Nov 2017, 09:47 PM #17Diamond Member
- N.W.Tasmania
- 1,407
28th Nov 2017, 10:41 PM #18
Layout & bending Jig Tables -Optical Centre Punch
Cool video.
I’m doing two tables one with angular radial patterns and one with the 50x50mm grid. The plans is to start drilling the radial one at the end of next week (fingers crossed). The other can be delayed a bit I guess if need be. What is your time frame?
I’m wondering how tight and accurate the jig holes are after drilling all those holes or if they start to open up. He seems to be just aligning by feel. I’d think a thicker jig would be more accurate than the thin edge of the angle iron in that regard. Are you going to do a box section with bushes again?
29th Nov 2017, 12:18 AM #19
Once the holes in the angle iron are drilled with the same core drill, the alignment of all subsequent holes will be spot on, Aligning the core drill with the magnet off is the 'trick'. Once you turn the magnet on, the drill won't move. I guess you have to be reasonably careful not to bump the magnet drill once its in the hole....
Seems to me that you won't even have to layout the whole table, just the drill jig (the angle iron and the tabs).
This is the easiest way I can see or thnk off to get the holes right.... The only thing I would do is use accurately fitting pins (or the shanks of suitable bolts), rather than the threaded part of bolts - which is invariably a smidgeon undersize.Cheers, Joe
29th Nov 2017, 08:56 PM #20Senior Member
- Castlemaine
- 244
Not sure if the holes will open up with the annular cutter. They certainly did with my mild steel bushes and the hand drill with standard twist drills.
the plan is to make a jig with removable bushes. Not sure of the material yet. I will use the Retro Welders idea on indexing one set of holes off the previous set which I did not do. I will be drilling on 100mm centres 1800x900 table top but could pop additional holes in if you want to use the jig.
I am a little way off having the time to get started on this project. Got to finish off some others first.
Piers
29th Nov 2017, 09:37 PM #21
2nd Dec 2017, 12:59 PM #22Senior Member
- Castlemaine
- 244
3rd Dec 2017, 09:57 PM #23
Just thinking aloud here, Piers and Dale:
If Piers makes a 100mm jig that you can use, I suggest you use that in the first instance.
You can then drill a couple of accurate holes in between and then use the 100mm jig registered to those two holes and off you go again with the next lot of holes. Do that in both directions for a 500 centreline pattern.Cheers, Joe
21st Dec 2017, 05:15 PM #24
I spent 6hrs on the table today and only got this far.
The black dots are done the two X I couldn’t do due to existing holes. Long long way to go yet.
I switched to water soluble cutting fluid and that quickly takes off the blue.
I was surprised at the amount of swarf generated.
21st Dec 2017, 09:30 PM #25
Dwarf's, are they hiding ?
22nd Dec 2017, 06:38 AM #26
31st Jan 2018, 04:22 PM #27
About 50 Holes left to drill in the first table....My lord the time it takes to manually align the centre pin in each punch mark takes ages. I watch for the pin to deflect in the hole then adjust until it is dropping in deadcentre from all sides. This also involves turning the magnet on and off repeatedly. Once the magnet is off there is a certain amount of time where there is still a residual magnetic pull where you can get some fine adjusting in before the thing comes loose and moves too freely.
I also have to spin the chuck to make sure it is the same all around and the with the drill running slightly score the surface and eyeball to see if the ring looks centred to the scribed marks and punch mark. The pin still is pretty loose so no matter how much I try I'm always fighting an uphill battle for accuracy.
Piers037 when did you say you would be making your jig??????
The apprentice sooking cos she wasn’t allowed to operate the drill
31st Jan 2018, 04:48 PM #28Senior Member
- Castlemaine
- 244
20th Feb 2018, 09:47 PM #29
Piers how did you go with the jig?
Sent from my iPhone using Tapatalk…..Live a Quiet Life & Work with your Hands
20th Feb 2018, 09:56 PM #30
First one down fully drilled and counter sunk.
I quickly relaid my line with marker to double check and lucky I did cos I missed one. Quickly did that one and done.
I had intended to be able to mount my ub100 bender and I measured the holes and all are equally spaced around the perimeter and should have dropped right in. Nope Chinese quality the diagonals are miles off the thing is ♦️ diamond.…..Live a Quiet Life & Work with your Hands
Automatic Centre Punch
By Twisted Tenon in forum METALWORK GENERALReplies: 11Last Post: 27th Sep 2017, 01:27 PM -
Sharpening Spring Loaded Centre Punch
By Fuzzie in forum METALWORK GENERALReplies: 7Last Post: 29th Nov 2015, 04:06 PM -
Optical centre punch for 'simonl'
By Steamwhisperer in forum METALWORK GENERALReplies: 53Last Post: 30th Aug 2012, 06:11 PM -
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 9th Aug 2012, 01:16 AM -
Centre punch mark magnifer
By neksmerj in forum METALWORK GENERALReplies: 15Last Post: 18th Jul 2007, 01:59 PM
