Results 31 to 33 of 33
Thread: Beam deflection
24th Nov 2017, 11:20 AM #31Senior Member
- Dec 2012
- emerald
- 161
Thanks sossity. I do have a little FOS up my sleeve though. The test lift was a metre span with point loading, but the actual lift will be around 850mm span with 4 point loading over 100mm.
It didn't even look like taking on a permanent set, even though I applied a little more "bouncing" load to it.
I'm feeling pretty confident!!! (famous last words. HaHa)
From my limited experience with failing beams, Ie, the engine crane mentioned previously, it happens pretty slow at first and then accelerates.
Eric
24th Nov 2017, 11:35 PM #32Most Valued Member
Is there a reason why you want to orientate the beam at 45 degrees? For example, to gain a little more height? Or are you doing it because you believe it is stronger?
25th Nov 2017, 07:11 PM #33Senior Member
- Dec 2012
- emerald
- 161
Square Hollow Section Strength/Deflection charts in Metric?
By joez in forum METALWORK GENERALReplies: 10Last Post: 17th Aug 2017, 07:33 AM -
Making a Steel Beam Flat
By grunto in forum METALWORK GENERALReplies: 15Last Post: 26th Jun 2017, 09:31 PM -
Steel grate rhs deflection
By oohsam in forum METALWORK GENERALReplies: 17Last Post: 17th Jun 2016, 10:19 AM -
Building a Aluminium I Beam Trailer
By gazza2009au in forum TRAILERS & OTHER FABRICATED STUFFReplies: 58Last Post: 30th Mar 2015, 11:45 PM -
Cornish beam engine
By neksmerj in forum METALWORK GENERALReplies: 5Last Post: 22nd Aug 2013, 01:05 PM
