Results 1 to 4 of 4
Thread: Form turning method
18th Nov 2017, 09:52 PM #1
Form turning method
I was looking at these methods described for form turning and wondering if all of them would be successful ? The spring loaded tool would chatter maybe ?
http://neme-s.org/Model_Engineer_Fil...%20Turning.pdf
19th Nov 2017, 04:19 PM #2Golden Member
- Nov 2010
- Gippsland Victoria
- 733
How about this.
Minimise the overhang by holding the tool very securely. Dont allow it to move.
Instead of a spring either
1. Place a dial indicator between the toolpost and the profile template try to hold the indicator to the same reading all the time. (seen on MEW forum)
or
2. Maybe spring isn't needed ? Use a solid bar with an appropriately shaped end to trace the profile, one end of the solid bar connected to toolpost the other end traces the shape.
When trying to do this sort of thing on chess pieces I had a lot of trouble with the shape of the "tracing tool". Need to do some more testing & learning.
Bill
Bill
19th Nov 2017, 04:57 PM #3Philomath in training
- 6,562
This any help?
//metalworkforums.com/f303/t198...ptical-profile
19th Nov 2017, 11:52 PM #4Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
the chatter . i think depends on the width of tool compaired to depth of cut.
thats an interesting link.
i all ways thought form tools were ground to match the shape of the profile required.
azz
Big deep cut Vee form tool
By steamingbill in forum METALWORK GENERALReplies: 6Last Post: 25th Mar 2016, 10:13 PM -
Form tools
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 14th Feb 2016, 07:34 PM -
Help with method of holding disk for turning down outside
By rodm in forum METALWORK GENERALReplies: 19Last Post: 13th Apr 2013, 07:45 PM -
face grove turning or other method?
By landslide in forum METALWORK GENERALReplies: 11Last Post: 12th Dec 2011, 05:10 PM
