Results 16 to 21 of 21
18th Nov 2017, 11:07 AM #16Pink 10EE owner
- 6,216
I would solder very thin pieces of copper together if I wanted a super cooler.
Cooling is done by surface area. The thinner the pieces, the more of them, the more surface area the greater the cooling.Gold, the colour of choice for the discerning person.
21st Nov 2017, 07:42 AM #17New Member
- UK
- 42
- 2
Ok the reason for "cutting" the fins into the piece of copper is to ensure the best thermal performance as any welded or "applied" parts will compromise coppers heat transfer qualities by forcing heat through solder or similar.
As for the answers im thankful but i think people are getting too deep : ) Im trying to find a way to cut the finest channels i can into copper. Short of making some sort of level slide system and using a steel razorblade to literally cut away at the copper though, it doesnt sound like there is going to be a quick solution!
Im now thinking if i use a X Y compound table and make a perfectly level slide for a blade, i could pass the blade over the copper and basically scratch a channel, move the table slightly and repeat. Would take a lot of time but its the only way i can think of cutting so finely into copper!
21st Nov 2017, 08:42 AM #18Most Valued Member
- Oct 2007
- 3,112
With all due respect I'd suggest you are both overthinking this and didn't properly read the comments about how to construct this by stacking thin stock. The function of the solder is to do nothing more than hold the stack as one solid block, the edges of the strips are still the points of contact with the heat source. The difference in thermal properties between that and machining from a solid block of copper would be so negligible I would challenge you to demonstrate any measurable difference.
You could "scratch" away the copper as you suggest. You could also use a single hair to friction saw your way through the block. Each idea being as equally stupid, hence I'm wondering if this isn't actually a wind-up. That being the case I wish you well in your time-wasting journey.
21st Nov 2017, 09:33 AM #19Most Valued Member
- 4,255
21st Nov 2017, 10:45 AM #20Most Valued Member
- Oct 2007
- 3,112
Indeed! The sliver of solder is between and separating the heat conducting fins, much like a layer of oxidisation ... therefore, if you're going to thermally saw your block of copper with a human hair, make sure you use OFC (Oxygen Free Copper), another area of quasi science where legitimate science is used to baffle a truck load of BS and make it sound legitimate!
21st Nov 2017, 01:21 PM #21Most Valued Member
- Healesville
- 2,129
EDM or wire cutting would be the way to go, how deep are your pockets
Small OD / fine thread on 4140 pre hard
By StrayAlien in forum METALWORK GENERALReplies: 12Last Post: 5th Mar 2017, 05:53 PM -
How to make U-channels out of glavanized sheet metal?
By LRAT in forum METALWORK GENERALReplies: 13Last Post: 27th Jun 2015, 06:25 AM -
Metric Left Hand Nut - Fine Thread
By electrosteam in forum METALWORK GENERALReplies: 3Last Post: 2nd Mar 2012, 12:41 PM -
Cutting very fine threads
By funkychicken in forum METALWORK GENERALReplies: 11Last Post: 12th Oct 2008, 06:55 PM -
so many channels, so little time
By mic-d in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 6th Jun 2007, 10:26 PM
