Results 1 to 7 of 7
Thread: GCS900-3DB DRO setup question
11th Nov 2017, 01:35 PM #1Member
- May 2005
- Cockatoo Vic
- 84
GCS900-3DB DRO
Purchased one of these cheap DROs for my cheap Chinese Mill.
Mounted the first (easiest) scale and couldn't resist trying it out.
Readout is backwards. Move X axis in a positive direction and the scale reads negative.
Manual says nothing about reversing direction. Does anybody know if this setting is available?
Or does the scale need to be reversed on its mounting. Seems odd if this is the case but no big deal.
And yes, I have been using CNC for years and I know which direction is positive.
11th Nov 2017, 03:35 PM #2Most Valued Member
- 4,890
Unless it is a fix by changing plug point or something just as easy just use it as is.
11th Nov 2017, 04:40 PM #3
If it's like my 4 and 5 axis ones you need go into advanced user settings.
The button had me stumped, it's behind the GCS900 brand writing, right in the middle on the front.
Feel around and you will find it.
Sent from my SM-G900T using TapatalkUsing Tapatalk
11th Nov 2017, 04:42 PM #4
Your password should be in your manual, but both of mine are the same 3211.
Probably best not to change it.
11th Nov 2017, 04:50 PM #5
Right here
11th Nov 2017, 05:45 PM #6Member
- May 2005
- Cockatoo Vic
- 84
Thanks for that Dave.
I will carefully poke about with that setting.
Seems that the Chinglish manual is a bit hard to follow for an old fella like me.
11th Nov 2017, 06:46 PM #7
No problem
I already had 2 Misters and a Sino for many years when I bought these 2, 4-5 years ago, but it had me stumped for days until I contacted them.
I don't know of any other units with a stupidly placed button like this. Some you have to hold a button on power up though.
That photo from the manual shows the procedure, if your instruction manual is different let me know and I'll photograph the other pages for you.
Electronics setup
By BobL in forum ELECTRICALSReplies: 0Last Post: 11th Jul 2017, 09:27 PM -
VFD Setup
By Auskart in forum METALWORK GENERALReplies: 6Last Post: 25th Sep 2016, 12:00 AM -
I have my MIG all setup, may just need a few pointers...
By mugget in forum WELDINGReplies: 25Last Post: 23rd Aug 2015, 09:38 AM -
Buffing Setup
By grunto in forum METALWORK GENERALReplies: 8Last Post: 4th Sep 2014, 02:23 PM -
3 Phase setup
By barkersegg in forum METALWORK GENERALReplies: 13Last Post: 8th Dec 2009, 12:17 PM
