Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    May 2011
    Murray Bridge S Aust.
    5,956
    Quote Originally Posted by Oldneweng View Post
    I recently watched a video where the poster recommended tightening a bolt a bit before trying to undo it. Just saying. You would have to be careful with a screw. Dean
    I've actually done this, tighten then loosen, and keep repeating, spraying a lubricant/penetrating solution helps a lot also.
  2. #17
    Nov 2007
    melbourne australia
    3,228
    I think he's gone.
  3. #18
    Jun 2017
    29
    3
    I forgot to say thanks for all your tips guys, I appreciate the help. I last posted on my phone but didn't check whether to see if it went through.
    In the end I got impatient and decided to try to undo the half worn screw head with an impact hammer and just completely stripped the head. So I went and got some pliers and just slowly twisted the screw out while sort of smacking the pliers at the same time to mimic the impacting/loosening, all this with some wd-40 just in case it was rusty (new grinder?).
    Also sorry for the confusion, thought I'd try a pun (tough nuts) but it didn't quite work as intended. It was a screw.
    ( Its my my fault here guys, I was late in approving this post - Grahame)
  1. MD45/HM46 Z Axis lead screw removal issue
    Last Post: 26th May 2013, 11:13 PM
  2. Key Removal
    By tongleh in forum METALWORK GENERAL
    Last Post: 15th Nov 2012, 01:48 PM
  3. Screw thread cutting for beginners
    By Kody in forum METALWORK GENERAL
    Last Post: 13th Jul 2011, 08:02 PM
  4. Metric Thread Cutting on Model 9A with Imperial Lead Screw
    By Rodd Perrin in forum THE HERCUS AREA
    Last Post: 21st Sep 2009, 02:14 PM
  5. screw gear removal??
    By turbo TA in forum METALWORK GENERAL
    Last Post: 8th Sep 2009, 12:34 AM
