Results 1 to 15 of 16
Thread: Starrett Machinist Level
3rd Nov 2017, 11:15 PM #1Golden Member
- Jun 2005
- Helensburgh
- 618
I borrowed a machinist level today to set up my sliding table saw and I think it has a problem. In one direction the bubble appears to be reluctant to move and it stretches itself as though the trailing end of the bubble is stuck. When it does move the bubble jumps to one end very fast and basically the bubble does not register small changes at all. In the other direction it seems fine and appears to register small movements as it should. It has been sitting in a tool box for many years and was bought second hand with an unknown history. I rolled it back and forth a lot and sometimes it appears to be OK after doing that, it is almost like the vial has developed memory because the level has been sitting so long. Has anyone ever experienced anything like this?
CHRIS
4th Nov 2017, 08:32 AM #2Most Valued Member
I got a Starrett No.98 that I bought S/H and I have not experienced this. Prior to using it I had only ever used a carpenters level for building stuff so it's increased sensitivity took some getting used to.
Got any pics?
4th Nov 2017, 10:51 PM #3Golden Member
- Apr 2008
- NSW
- 537
It sounds like it's too cold and the spirit inside contracts making the bubble long and skinny too long for the glass curvature so it breaks up easier . Warm it up by putting under your jacket for a while . If that don't fix it it may have a fine crack in the glass that let in some air but still maybe spirit tight . To test the repeatability place it on a machined surface with a side and end stop so it goes back exactly the same when you reverse it . if the bubble stays exactly in centre both ways it's accurate . If not you can adjust some of them using the screw head at one end of the housing . The bubble should be no longer than the two centre lines but some do vary a bit .
4th Nov 2017, 10:54 PM #4Golden Member
- Jun 2005
- Helensburgh
- 618
4th Nov 2017, 10:58 PM #5Golden Member
- Apr 2008
- NSW
- 537
It sounds weird . If it has an adjustment someone may have stuffed it up . Use the reverse about test and see if the bubble centres each way . Might be cracked .
4th Nov 2017, 11:02 PM #6Golden Member
- Jun 2005
- Helensburgh
- 618
CHRIS
4th Nov 2017, 11:07 PM #7Golden Member
- Apr 2008
- NSW
- 537
That sounds like a good plan , you don't want to be blamed for anything.
5th Nov 2017, 09:08 AM #8Diamond Member
- N.W.Tasmania
- 1,407
It does sound weird, and I have no idea what would be causing the behaviour, but I doubt that a crack which let air in, but was still spirit tight would be the cause. The vials would not be evacuated of air, or would at least have a gas, perhaps nitrogen, if not just air, because if they were put under vacuum, the spirit would begin to boil.
Perhaps an email to Starrett might be in order, I for one would be interested in their response, but I agree that it would be inadvisable to fiddle with it before showing the owner the issue and getting approval to make any adjustments.
Rob.
5th Nov 2017, 10:41 AM #9Golden Member
- Apr 2008
- NSW
- 537
I have been using this kind of machinist level all my life and they can leak air in over time from a fine crack and not loose all the spirit inside .
The sealing process can be faulty also . Sometime you take the vial out and you can't tell what is wrong but you know it's crook in some way and needs a new one .
The level could have been no good from day one .The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
10th Nov 2017, 01:24 PM #10Most Valued Member
I could hazard a guess at what the problem, but won't. Do you have a video of the issue?
10th Nov 2017, 05:04 PM #11Golden Member
- Jun 2005
- Helensburgh
- 618
11th Nov 2017, 09:46 AM #12Most Valued Member
- 4,255
11th Nov 2017, 02:29 PM #13Most Valued Member
- 5,945
I'm one too, mine just does text and phone calls. Yes I'm testically challenged.
11th Nov 2017, 04:26 PM #14
Around the world there are 40 Billion photos and 35 Million videos taken each day that never see the light of day again or if they do the lucky viewer wishes they never came to visit. I don't watch upright aspect Mobile phone YouTube videos. Why would you? And smart device photos seem to have a life of their own when it comes to forums. I use my mobile camera to take pictures of products and prices when in town and very little else. They only get looked at by me and never leave the phone. I did have a phone that could take glorious full circle panarama photos, stiching them all together on the fly. That was a worthwhile use.
I made up the numbers.
ps It is useful to have a phone camera in a situation like this when you don't have a real one.
11th Nov 2017, 05:28 PM #15Golden Member
- Jun 2005
- Helensburgh
- 618
I'm trying to forget where my mobile phone is, it must be at least 12 months since I used it for a phone call and I wouldn't have a clue how to text or do anything else on it if it can even do that. I used to walk around with three mobiles in my last job and when I retired I stopped using mobile phones. As for YT videos taken on mobiles, if I open one it gets the finger straight away and I refuse to watch.
CHRIS
Starrett 132-18 level
By tofelofogus in forum ANTIQUE AND VINTAGE MACHINERYReplies: 2Last Post: 12th Jan 2017, 10:34 AM -
SOLD: Precision level like Starrett 199
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 20th Jun 2012, 08:54 PM -
SOLD: Starrett 98-8 Level.
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 9th Jun 2012, 10:40 PM -
Machinist's Level
By Gavin Newman in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 24th Feb 2011, 07:36 AM -
Starrett Spirit Level
By Groggy in forum METALWORK GENERALReplies: 2Last Post: 14th Jan 2005, 08:47 PM
