Results 1 to 5 of 5
Thread: Pipe bender
21st Oct 2017, 11:27 AM #1
Pipe bender
been looking around for a pipe bender design , this one is basic but its looks effective . I want to bend gal. pipe , the 1" od
https://www.youtube.com/watch?v=9ErSCmabAFg
21st Oct 2017, 12:29 PM #2Most Valued Member
- 70
- 1,513
Looks like hard work but effective. Could do with extension to table to keep bends parallel and built in gauge such as a larger ruler, to set lengths.
Nev.
21st Oct 2017, 02:24 PM #3Most Valued Member
With that type of bender, you could do tube very easily, the bigger diameter and wall thickness the harder the work. If you've a tractor or hydraulic pump, you could fit a ram to make life easier???
21st Oct 2017, 05:30 PM #4Senior Member
- Dec 2013
- 201
I've had a bender like that one for 3 decades. We used it in low volume production on 1" x 1.2 and 1.6mm wall ERW tube. It must have done 100,000 plus bends and is still going strong. It makes very neat bends with minimal narrowing of the tubes. We made various extensions and guides as Nev describes above, and with these it would hold dimensions between bends to a couple of mm, more than enough for the fabrication we were doing.
It's probably overkill for gal pipes though. There are simpler systems for that.
Graham.
21st Oct 2017, 05:52 PM #5Most Valued Member
When you do get a bender, make sure that the former is a close fit, some are 1-2 mm larger than the pipe/tube causing kinks or a sharp bend in the pipe, DAMHIKT
This is more common on hand/air operated hydraulic pipe benders, the ones that turn you into Popeye.
Swadesir 15b pipe bender
By russ57 in forum METALWORK GENERALReplies: 14Last Post: 27th May 2017, 12:04 AM -
Pipe bender
By tinkera in forum METALWORK GENERALReplies: 6Last Post: 1st Jul 2013, 12:27 PM -
Pipe Vice-pipe bender identity and info please
By Log in forum METALWORK GENERALReplies: 18Last Post: 18th Apr 2012, 01:14 PM -
Pipe Bender WIN!
By BenM78 in forum WELDINGReplies: 3Last Post: 20th Jul 2011, 11:12 PM -
Hydraulic Pipe Bender
By diz in forum WELDINGReplies: 10Last Post: 4th Jul 2011, 05:11 PM
