Results 1 to 6 of 6
12th Oct 2017, 11:50 AM #1Senior Member
- Apr 2013
- Toowoomba Qld
- 401
grinding noise in my head... of the knee mill
So I think I need to pull down the head in my Bridgeport clone milling machine. Was cleaning up some large stock and had used a face mill in high speed. Worked fine, finished that and for the hell of it figured I would run my shop made fly cutter over the top to clean it up. The fly cutter has to have the spindle run in reverse, was getting some chatter so was running it in low speed / back gears. Wasn't taking a heavy cut, only 0.2mm depth. Seemed to run fine but then flipped the material over, chucked the face mill back in and went to run it.
I think the mill is now angry at me as it sounds like it's chewing rocks when running it on high speed
Before I go stripping it down does anyone know what could be the cause of the sound ?
Extra info
When spinning the spindle by hand in high it seems to bind like it's winding up and grabbing the brake or something, turn it a bit more and it lets go again.
When engaging the low speed I have to put shims under the top collar so it lifts high enough that the gears don't rub together, has been like this since I got the mill so never thought much of it and don't use low speed much.
To me it looks like there is a burr on the teeth of the dog gears so not sure if that is possibly stopping the gears coming together more ?
Any help appreciated, now I'm off to look up how to disassemble the top part and probably to make some special tools to do the job...
Wayne
12th Oct 2017, 12:13 PM #2Philomath in training
- 6,540
That sounds a bit like a loose fastener bouncing around. Perhaps check everything accessible is tight.
13th Oct 2017, 11:36 AM #3Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Good news and bad news
Found the problem, Michael was sort of right, it was a loose fastener of sorts
The nut labelled 74 in this picture had come loose, will need to replace parts numbered 73 : Lockwasher & 74 earing locknut as they are both are damaged.
Will need to touch up the thread on the bottom of 57 : Splined Gear Hub but should be able to salvage it.
Some extra info incase anyone lands at this thread trying to diagnose their own. When turning the spindle by hand it would appear to wind up in one direction, bind a bit then let go and spin freely again. Wasn't able to engage the quill power feed and by pulling out the shift lever for it could see that it had come loose and was floating around the bottom of the shaft. Only wish I had of found this before pulling down the rest of the head...
Now to find some spare parts. It's a bridgeport clone but appears to be all metric, having a quick check on the thread looks like it might be M40x1.5 but will need to do another check as was half asleep last night when checking.
Wayne
13th Oct 2017, 03:35 PM #4Most Valued Member
- 5,942
Glad to hear it wasn't too drastic a problem, should be a reasonably cheap fix?
24th Oct 2017, 03:27 PM #5Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Final update, mill is back in action
Nut was sorta a N08, except that the shaft was not made to spec and the nut is meant to be thinner then the M08.
Ended up having to re machine it in the lathe. Put a piece of stock in the lathe, machined a pocket and used Loctite 641 to hold the nut in the fixture, turned it thinner then recut the threads oversize as the shaft was not not quite 1 9/16" - 18tpi, Thread pitch was about 5 tho oversize.
Washer was a W08 but once again not quite to spec, the tang that holds the shaft was to wide as the keyway cut in the shaft was to narrow. Didn't take long with a hand file to make it fit tho.
Was happy that didn't even have to make any special tools, a ER40 hook type spanner was just the right thing to tighten the nut. Not sure if there is a torque spec or anything but gave the spanner a few whacks with the mallet until the washer lined up and bent the tab to hold it in place
Happy camper again, think the problem may have actually been in the mill all along as always had a bit of a rattle but is now quite. Got to be happy with that.
Wayne
24th Oct 2017, 06:54 PM #6Most Valued Member
- 5,942
Glad to hear that all is well with your head (of the mill) now
Grease to use in mill head
By Justin Wright in forum THE HERCUS AREAReplies: 3Last Post: 17th Feb 2016, 03:23 PM -
Cross slide bronze nut - grinding noise/issues
By Hornetb in forum THE HERCUS AREAReplies: 17Last Post: 16th Aug 2013, 06:02 PM -
Noise from MH 48 mill
By Ben Dono in forum METALWORK GENERALReplies: 33Last Post: 11th Feb 2012, 05:50 PM -
Boring head for DM 45 Mill ?
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 20th Nov 2011, 06:03 PM -
Knee Mill Gas Spring Rating
By electrosteam in forum METALWORK GENERALReplies: 5Last Post: 6th Aug 2010, 01:12 PM
