Results 1 to 4 of 4
19th Sep 2017, 06:24 PM #1Most Valued Member
Dodging Dovetail Headaches: 7 Common Dovetail Mistakes
Found this on an email sent to me by Harvey Tools, and thought it might be of interest to the members.
Dodging Dovetail Headaches: 7 Common Dovetail Mistakes - In The Loupe - Machinist Blog
21st Sep 2017, 03:04 PM #2Golden Member
- Apr 2008
- NSW
- 537
Be very careful of those dovetail recommendations to climb mill . The tools they are referring to are quit a bit more rounded and stronger than the 45 degree or 60 degree dovetail cutters commonly used by hobbists and CNC machines have full movement control in both feed directions . If you climb mill them on a sloppy manual mill the fine outer points will break off easily . I know I have broken a few that way . Stick with conventional milling and take light cuts .
Machine a slot first to ease the load on the cutter and to allow coolant to flood in and get swarf out . Try to avoid a dovetail that requires only one pass . Cutting on one side at a time is better .The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
21st Sep 2017, 03:53 PM #3
21st Sep 2017, 08:46 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
Most of that info is for milling dovetail Oring grooves in a CNC mill.
Dovetail cutter
By Pete F in forum METALWORK PROJECTSReplies: 14Last Post: 3rd Jul 2016, 10:09 AM -
Dovetail Cutter
By Oldneweng in forum METALWORK GENERALReplies: 27Last Post: 9th Jun 2014, 10:14 AM -
Dovetail Measurement?
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 29th Dec 2012, 10:47 AM -
Cutting a dovetail
By morrisman in forum METALWORK GENERALReplies: 56Last Post: 7th Mar 2012, 06:38 PM -
Using dovetail cutters
By mav_walrus in forum METALWORK GENERALReplies: 6Last Post: 18th Jul 2011, 10:30 PM
