Results 1 to 8 of 8
    Sep 2007
    Country West Oz
    77
    169
    Default Chuck for unknown Chinese lathe
    Our local Mens Shed have been given a large fairly old 7.5 horse power Chinese lathe , it has nothing written on it in English.
    It seems like quite a good machine, although it looks like it has had a pretty hard life.
    The problem is that it came with no tooling or accessories whatsoever, and only a 3 jaw self centering chuck, 250mm diameter.
    The owner purchased it years ago and never used it, and knows nothing about it. It has been sitting in a shed for many years.
    It has been decided that the first thing we will do is clean it up and get a 4 jaw chuck for it, and I have been given the job of sourcing the chuck.
    The original chuck has 4 studs and a locating dowel, this is mounted to the lathe and held with a rotating ring and then the nuts tightened to secure it.
    I have looked everywhere I can think of and have not been able to find a chuck with this type of mounting.
    We could make an adapter to fit a readily available chuck I suppose (be a good project), but I am wondering if anyone knows of this type of mount and where we may be able to get one.
    I have a picture of the mounting plate, but not of the lathe. I will take some next time I'm there and see if somebody can identify it.
    I'm sure with the knowledge available on this Forum, which is extensive, someone will know all about it.
    Thanks,
    Bradford
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Have a look here -
    Lathe Spindle Nose and Backplate Fittings
    near Rockhampton
    6,217
    Is it a DIN55027 type spindle nose?
    https://www.google.com.au/search?q=din55027
    Sep 2007
    Country West Oz
    77
    169
    Thank you gentlemen for your prompt replies,
    It is very like DIN55027 but it has no taper and also the mounting stud spacing is different to any listed.
    I will be at the mens shed in the next couple of days I'll take some more pictures and some accurate measurements.
    Bradford
    Sep 2007
    Country West Oz
    77
    169
    Here are more photos of the spindle nose and also the lathe.
    The spindle nose is 180mm diameter and the stud spacing is 148mm .
    The lathe is quite large with a swing over the bed of about 580mm and distance between centers of around 1200mm.
    The nameplate has a spot for the date of manufacture but nothing is stamped on it.
    Sorry some of the pics are sideways
    20170912_141641[1].jpg20170912_141733[1].jpg20170912_141623[1].jpg20170912_141537[1].jpg20170912_141513[1].jpg
    Bradford
    near Rockhampton
    6,217
    I am guessing it is something they have borrowed from some UK lathe manufacturer. Lang for example made their own spindle nose design that other manufacturers borrowed.
    I think you are out of luck to find a new one. It obviously uses the OD as a locator.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Does that knurled ring on the spindle rotate independently of the main spindle, and does it also have elongated holes?
    In regards to a mounting / backing plate one would just need to be made to suit your chuck with correct PCD and locateing pin.
    Sep 2007
    Country West Oz
    77
    169
    Yes
    I'm thinking the best way to go, would be to buy a readily available chuck and make an adapter to suit.
    I am planing to take that idea back to the next meeting and see what the rest of the fellas think about it.
    Thanks for your input
    Bradford
  1. Collet chuck.unknown use.
    By azzrock in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 15th Mar 2017, 07:58 PM
  2. Another MARS lathe. Model Unknown.
    By hudnut in forum METALWORK GENERAL
    Last Post: 27th May 2015, 08:08 PM
  3. New Chinese Lathe
    By MarkZ in forum METALWORK GENERAL
    Last Post: 30th Oct 2012, 05:57 PM
  4. Unknown Hercus 14x40 Lathe
    By JohnAXA in forum THE HERCUS AREA
    Last Post: 14th Mar 2011, 08:57 AM
  5. Gear Life Chinese Lathe
    By barry240 in forum METALWORK GENERAL
    Last Post: 15th Jun 2009, 01:06 AM
