Results 31 to 45 of 105
Thread: Home Made Lathe
10th Sep 2017, 07:50 PM #31Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
It takes some practice, (I'm still learning myself) YouTube and a protractor have become my best friend
10th Sep 2017, 09:15 PM #32
Take a look at the videos on this page.
https://www.youtube.com/results?sear...l+bit+grinding
Tubalcain does a good job of showing how to grind tool bits as he shows the steps on a block of wood and so it is very easy to see what is going on. It is hard to get the idea on a small bit of HSS.
10th Sep 2017, 10:05 PM #33Golden Member
- Vic
- 48
- 544
how about this one?
Small Lathe | eBay
11th Sep 2017, 03:15 PM #34Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Thanks for the links i will check them out soon, i picked up a small bar 100x36mm cost all of $3.50 locally, i was looking at buying some from ebay for $15
i just had a brain fart moment and was not thinking i tried to spin the 100mm bar in the lathe and the motor is placed in a clam shell it popped one side out should be easily fixable but it was spinning the whole bar good untill the motor started to rub on the plastic
i may look into trying to machine something like a clam shell out of a small block of aluminium to mount the motor more steady
11th Sep 2017, 10:35 PM #35Most Valued Member
- Aug 2009
- 1,844
Hey Guys, Good news it took me around 1.5-2 hours machining i have now completed one side of the wheel spacers for one wheel haha yes u can have a laugh a lot of the time i was checking measurements with the vainer calipers as not to under cut the piece
i did learn that i should have cut the stock as short as possible to the required length i way over cut it and machined alllllll that off it was labour intense and time consuming but i enjoyed it
i started off with 36mm x around maybe 35-40mm wide the overall length of the piece i needed to make was 12mm so u can imagine the joy i had machining all that off on a tiny toy lathe haha
the final finished spacer came in spot on measurements or some were 00.03mm out now i donno how exact you guys like to be or precise but i consider that a good effort with using what i have on hand
the center hole still needs to either be drilled I'm not sure if to drill or machine it what's everyone's thought's on this?
now some pictures I have been wanting a lathe for years and now i am doing it and loving it
bugger half of my pictures won't load to this site
12th Sep 2017, 01:13 AM #36Senior Member
- Apr 2013
- Toowoomba Qld
- 401
normally when making a spacer or something like that you would drill it out with a drill in the tail stock then go in with a boring bar to bring it to final size and make sure it is concentric (or you can use a reamer which will get the size spot on but won't fix if the hole is off center)
Btw I'm going to call it now, you have toyed with a lathe now and will soon be out looking for a fix and buying a bigger / better spec'd lathe. Once you have been bitten there is no saving you...
12th Sep 2017, 01:36 AM #37Most Valued Member
Hi Gazza, Don't know if you knew this, but you can end up with a small fortune metal turning??? You need to start with a BIG ONE though . Welcome to the hobby of a bottomless pit. There's always another special tool required, that you can't make but can't do without. DAMHIKT
12th Sep 2017, 12:00 PM #38normally when making a spacer or something like that you would drill it out with a drill in the tail stock
With regards to MasterSpoon's prediction, I won't mention how deep my lathe can cut in one go.
12th Sep 2017, 12:42 PM #39Most Valued Member
- Aug 2009
- 1,844
Ah bugger if it didn't take so long to machine i would make another one but by drilling the hole first, Can someone give me a tip on how to zero the dials? at this moment i am just machining material off and using the vainer calipers to measure to size i am also using the .05 as a slight guide as to how much i am removing, Last night i had a really close look at the handles/knobs it actually reads .02, .04 etc.. i was previously just counting 5 lines but i would like to learn how to zero the dials and do it the proper way
12th Sep 2017, 12:59 PM #40Most Valued Member
- Aug 2009
- 1,844
Forgot to add when i had the problem yesterday i ended up leaving off the belt and motor face cover this was rubbing and binding the motor i wasn't sure how to fix it as every attempt to repair kept binding, once it was removed the power and rpm increased a lot so much i noticed it when machining and i could hear the higher rpm pitch noise
i think my next lathe will be this one https://www.aliexpress.com/item/Big-...1-17e881fca362
12th Sep 2017, 04:34 PM #41Senior Member
- Apr 2013
- Toowoomba Qld
- 401
12th Sep 2017, 04:51 PM #42Most Valued Member
- Aug 2009
- 1,844
MS I would love a lathe that size but i am out of room mate, i have so many tools and saws it just clutters half of my 2.6x2.6m shed i just don't have anywhere to keep storing stuff in this shed i have 2 full size motorcycles in there, i do have 2x 2 meter benches in there but i have all sorts of crap in there too 10% organized 90% not haha i just don't have any top bench room i am currently doing a full motor rebuild on my DRZ400 motorcycle and there is just not enough space even if i could make room i have the problem of the lathe shavings and my motor rebuilding hobby colliding in a not so good way
i am constantly fighting with the wood drop saw on where to place that... i have two other bench metal drop saws plus various other saws and tooling all in the way
with these little hobby/toy lathes i can bring them inside and place them on the kitchen table 2kg and 35x25cm in size isn't a big deal where as the lathe u suggested looks stationary? also i have the luxury of air conditioning inside something the shed doesn't have
i do like that lathe tho it looks similar to those red models on Ebay SIEG i think they are called but it's all about real estate
12th Sep 2017, 08:41 PM #43Ah bugger if it didn't take so long to machine i would make another one but by drilling the hole first, Can someone give me a tip on how to zero the dials?
12th Sep 2017, 08:55 PM #44Most Valued Member
- Aug 2009
- 1,844
It goes 0,0.2,0.4,0.6,0.8 back to 0, when i previously mentioned i was cutting 0.5 that was 5 lines or between the 0.4 and 0.6 markings
I'm still unsure if this lathe is metric or imperial, i tried machining down the 36mm stock i cannot remember what number i came to but it was a even number than i took off from memory 0.2 and it took a lot more off than 1/5th of a millimeter but again i cannot remember the exact sizes but i do remember thinking this may have been a imperial machine
unless where i am going wrong is the machine reads 0.2mm but really its machining 0.2mm off the radius so there for 0.4mm? i donno i can't work it out i have tried tho
12th Sep 2017, 09:10 PM #45Most Valued Member
- 4,890
Might be time to invest in an other couple of tools,dial indicator and magnetic base and a couple of micrometers.
Another home made lathe
By nadroj in forum METALWORK GENERALReplies: 16Last Post: 28th Apr 2013, 11:48 AM -
Home made Lathe
By simonl in forum METALWORK GENERALReplies: 8Last Post: 26th Apr 2013, 08:16 PM -
Lathe Taper Attachment Home Made.
By aametalmaster in forum METALWORK GENERALReplies: 3Last Post: 2nd Jan 2012, 10:46 AM -
Impressive home made lathe
By racer123 in forum METALWORK GENERALReplies: 20Last Post: 15th Oct 2011, 03:26 PM -
[repost] Home Made Lathe - Can anyone turn a headstock spindle for me?
By Skew ChiDAMN!! in forum METALWORK GENERALReplies: 1Last Post: 26th Aug 2007, 04:04 PM
