Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
  1. #16
    Oct 2009
    Upwey VIC
    187
    Quote Originally Posted by Bryan View Post
    I have a Lantaine-based lathe. On mine the front tumbler is 20T and the rear is 25T. I worked out the pitch once but I've forgotten. 12DP rings a bell.
    It looks like Ash's lathe has a 22T gear on the front tumbler.
    If Ash can measure the outside diameter of this gear we can determine the DP/MOD more accurately.
    Andrew
  2. #17
    Jun 2007
    Vic
    48
    544
    If you are out of luck, then check the distance D1 and D2 together with exiting gears, you will be able to get one made.
  3. #18
    May 2010
    Lower Lakes SA
    58
    2,607
    This is a 40T Hercus gear that matches mine. Would the 16 mean 16DP? OD is around 66.6mm.
  4. #19
    Mar 2013
    Moama
    39
    Hi Jackaroo
    It is a S1124A
    Ash
  5. #20
    Mar 2013
    Moama
    39
    Thanks Roger
    I will give them a call.
    Ash
  6. #21
    Mar 2013
    Moama
    39
    Thanks Bryan
    That looks very similar to mine.
    Hopefully getting closer
    Ash
  7. #22
    Mar 2013
    Moama
    39
    Hi Gents
    I ran Hare and Forbes, and as Roger suggested, given it was not one of their lathes they couldn't help.
    He suggested I contact Quality Machine Tools which I have done and sent a couple of photos to them to see if they can help.
    Fingers now crossed. If not I'll do some measuirng as you suggest and see if soemone will make me one.
    Ash
  8. #23
    Jul 2010
    9,088
    Hi Ash,
    Did any other gears come with the lathe?
    Looking at your picture it appears to be a imperial lead screw, with a 120/127 compound gear for metric pitches or vice versa. So I'd think there should be some more gears. I cant see a metric threading chart though.
    Do you want to cut metric threads?
    Just that while you're chasing up gears you may as well get them all if you'll need them.
    A better picture of the charts on the front of the lathe may help.
  9. #24
    May 2010
    Lower Lakes SA
    58
    2,607
  10. #25
    Mar 2013
    Moama
    39
    Hi Ash,
    Hi Stuart
    No gears came with lathe. I would ideally like to cut metric threads one day. So the best thing would be to change all the gears?
    Photo of chart below. It is exactly the same as one I found on a Honden L-900B
    Hope this helps.
  11. #26
    Mar 2013
    Moama
    39
    No luck with Quality Machine Tools either. Didn't want to know anything about it. Bugger.
  12. #27
    Jul 2016
    35
    1,522
    If you are really patient and supply the stock and a drawing i would be happy to make the gear for You, but i don't have a heap of workshop time at the moment, if you have a mill i could also lend a dividing head on a short term basis.
  13. #28
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Hi Ash,
    given that you are in Moama and I'm in Bendigo, why don't you come and visit one day soon, and bring the gear you have with you. I have a largish collection of gears of that size and may well have what you need. The prerequisite is of course that you figure out what number of teeth the missing gear was. Have you tried putting the one you have in the place of the missing one yet to see if it meshes there?
    Cheers, Joe
  14. #29
    Mar 2013
    Moama
    39
    Hi Caskwarrior, thanks for your generous offer. I have received the same generous offer from another member (as well as a lot of great advice).
    I am astounded at the generosity of the people on this forum.
    Thanks again and I will keep your offer in mind.
    Ash
  15. #30
    Mar 2013
    Moama
    39
    Hi jhovel
    Thanks to you too for your generous offer. I would love to take you up on the offer. I will keep researching the gear I am missing and get back to you.
    Thanks again and I look forward to meeting you in Bendigo (hopefully) soon.
    I haven't tried the existing gear as you suggest. I didn't think of trying that, but I will this weekend and let you know.
    Ash
  1. DM 45 Standaco speeds
    Last Post: 3rd Sep 2011, 08:09 PM
  2. Gear Hobbing on a Lathe
    Last Post: 31st Aug 2011, 11:55 AM
  3. Gear Life Chinese Lathe
    By barry240 in forum METALWORK GENERAL
    Last Post: 15th Jun 2009, 01:06 AM
  4. Boxford Lathe - Back Gear
    By fluxcored in forum METALWORK GENERAL
    Last Post: 6th Feb 2009, 11:09 PM
  5. Standaco's DM45 Mill/Drill ?
    By steran50 in forum METALWORK GENERAL
    Last Post: 8th Jan 2009, 08:23 PM
