Results 1 to 9 of 9
2nd Sep 2017, 01:43 PM #1
Suggestions for rounding over sharp edges on engineers square and combination squares
Suggestions rounding over sharp edges on engineers square and combination squares?
I've just purchased reasonably in-expensive engineers square and combination squares.
All have sharp edges.
Any suggestions on how to make them not so sharp?
Should I leave them?
Can I dull them by microns?
Thanks in advance.Thanks,
Barry G. Sumpter
Proud Tritoneer
( see my other 40 posts under BarryGSumpter )
May Yesterdays Tears Quinch the Thirst for Tomorrows Revenge
2nd Sep 2017, 01:52 PM #2Philomath in training
Put a strip of emery on a flat surface and gently pull the edge in question along it. All you should be doing is taking the sharp off.
2nd Sep 2017, 03:02 PM #3Senior Member
- Jun 2013
- Tasmania
- 257
A quick brush (light pass) past a wire wheel on the grinder?
Usually enough to break the edge.
2nd Sep 2017, 04:42 PM #4
Hi Barry,
A quick swipe with a fine stone is usually enough.Best Regards:
3rd Sep 2017, 02:31 AM #5New Member
- Apr 2014
- Little River
- 3
3rd Sep 2017, 10:09 AM #6Member: Blue and white apron brigade
I found a Scotchbrite wheel is good for this sort of things,
3rd Sep 2017, 09:28 PM #7
I know a well known boutique maker uses a 3m Scotchbrite debuting wheel on his bench grinder for just this purpose on his squares.
Sent from my iPhone using Tapatalk…..Live a Quiet Life & Work with your Hands
3rd Sep 2017, 11:27 PM #8Philomath in training
Just remember that depending on the grade, that Scotchbrite can be might aggressive.
4th Sep 2017, 09:13 AM #9Most Valued Member
I would use a stone too.
Pre-relieving cutting edges
By bob ward in forum METALWORK GENERALReplies: 14Last Post: 3rd Dec 2015, 10:56 AM -
Precision Engineers Square
By Oldneweng in forum METALWORK GENERALReplies: 26Last Post: 8th Jun 2015, 09:34 PM -
Black Engineers Square
By Stustoys in forum METALWORK GENERALReplies: 11Last Post: 22nd Feb 2014, 09:48 PM -
B grade Engineers square, what are the tolerances?
By simonl in forum METALWORK GENERALReplies: 4Last Post: 2nd Aug 2012, 10:50 PM -
Wanted Large Engineers Square
By johncee1945 in forum METALWORK GENERALReplies: 2Last Post: 19th Apr 2012, 08:30 PM
