Results 16 to 20 of 20
Thread: Macson surface grinder
5th Mar 2018, 04:12 PM #16
The simple option would be to file a square groove into the bore of a standard washer, weld/braze/silver solder a small square into that, filling the groove and sticking into the bore by the required depth for the keyway and then file the shape to a neat fit into the keyway. Should take about 15 minutes. Sometime a little hand work and hand fitting is a LOT faster than laser cutting and the required CAD to get there....
Laser cutting wouldn't have even occurred to me for a one-off...Cheers, Joe
5th Mar 2018, 06:02 PM #17Senior Member
- Aug 2013
- 229
Hi Alf
I like Joes suggestion, or as an alternative, with a bit of patience, you could cut the shape with a jewellers saw.
I did have some trouble removing the retaining nut, so had to make a special tool and use a rattle gun
Note to self - use thread lube on the nut.
Pete
7th Mar 2018, 09:23 AM #18Intermediate Member
- Dec 2013
- Mt Waverley Vic 3149
- 81
- 44
Is there something wrong here or is it me; (od - id)/2 should equal width of collar - 53.4- 32.1 = 21.3 divide by 2 = 10.65 not 12.6. Can someone explain what I am doing wrong.
Bob
7th Mar 2018, 09:28 AM #19Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
12.6 is measured over the key.
7th Mar 2018, 11:14 AM #20Intermediate Member
- Dec 2013
- 81
- 44
Thank you, I didn't notice the key - should have out my glasses on!!
Macson 2 as surface grinder
By StrayAlien in forum METALWORK GENERALReplies: 8Last Post: 18th Sep 2016, 09:41 PM -
By Petip in forum METALWORK GENERALReplies: 13Last Post: 26th Oct 2015, 08:02 AM -
Macson surface grinder, pics
By Burner in forum METALWORK GENERALReplies: 9Last Post: 29th Jul 2014, 12:22 AM -
DONE: Macson Surface Grinder
By GZBMW in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 18th May 2013, 11:14 PM -
SOUTH AUST Macson Surface grinder
By Kon R in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 22nd Oct 2012, 11:54 PM
