Results 16 to 28 of 28
6th Aug 2017, 05:36 PM #16Senior Member
- Jul 2017
- Burleigh heads QLD
- 29
- 114
Nick mueller has some pretty great videos and stefan does a great two part introduction on scraping. you'll need a a surface plate, camelbacks a decent granite square and an assortment of indicators a hand or power scraper etc. I was intending to have people practice on smaller machine tools at club meetings and then lend out camelbacks under strict conditions so people could scrape in their larger machines at home as its pretty dam hard to get a hold of camelbacks in this country.
the connelly book is apparently the bible of hand scraping but I only had a brief read while I was in denmark. you also have to remember there are a great many reference surfaces on mills that will point you in the right direction. A thick concrete slab is of course very important for a lathe otheriwse you're struggle to keep it leveled in. I've seen a few people cut out a section of their slab where they intend to put the lathe and dig an extra deep section for a thicker slab.
Stefan's intro to scraping:
https://www.youtube.com/watch?v=QJXqHpSh3SE
Nick mueller showing some alignment techniques:
https://www.youtube.com/watch?v=AzhmMp2fLSw
7th Aug 2017, 01:18 PM #17Most Valued Member
- Australia east coast
- 2,713
You don't need a *camelback* straight edge. You do need one or more straight edges. The parallel beam types are perfectly usable with the added bonus that you can put a sensitive level on top of them - assuming the top & bottom are parallel.
I've had over a dozen cast up and sold to various people over the years. Ditto for right angle squares. Once I get home in a few days I'll probably get more right angle squares cast up, maybe some more dovetail base straight edges.
You definitely do need or have ready access to a granite surface plate and if you're doing a lot of scraping, a Biax scraper is almost essential too.
None of this stuff is cheap in terms of time or money.
As for slab thickness a lot depends on how solid the substrate is. I have a 4" reinforced concrete slab. There are machines massing up to 3.8 tonnes (heaviest one) sitting on it. The one I care most about, a Kearns S type HBM, has not moved at all as checked on a few occasions using a sensitive level. But - I laid the slab after backfilling and rolling the substrate with a heavy vibrating ride-on roller.
Now something like a biggish slideway grinder needs its own deep & solid base to isolate from vibration as well as stability.
PDW
19th Aug 2017, 07:04 PM #18New Member
- Mar 2017
- Shreveport
- 9
I certainly would enjoy that tremendously if you were anywhere near Northern part of Louisiana !
I am a newbie to this whole amazing field of machining and scraping etc.
I have resentful gotten a Shaper that I want to completely go thru and I have to pick up a 9" south Bend lathe , it could possibly be a 10" It's be so long since I have seen it. I used to work for this older Italian gentleman that had it in his garage before he made it into a parts house in the '60's and I want to restore it for his memory. And I know it needs scraping all over. So I would love to join a group like your talking about. I do have manual scrapers and most of ness. stuff but I could sure use some dovetail angles plates or whatever is correct term. Would like to get some castings and scrape them into masters but can't find any affordable around here.
Well I sure hope you get a great group going I'm sure it will make fore a great time and we need to spread the dying Art of Scraping to as many as possible.
Mike
30th Sep 2017, 12:31 AM #19Senior Member
- Mar 2017
- Brisbane
- 245
Anyone know of a good source for us Aussies for a carbide hand scraper? Or just the bits themselves?
30th Sep 2017, 01:39 AM #20Senior Member
- Jul 2017
- 29
- 114
the scraping/rebuilding club is having a BBQ meet and greet on the 7th and possibly the 8th of October, Andy's bringing along two little containers full inserts so I'm sure he could spare one and I think I could whip up a scraper handle over a few beers if you're keen.
30th Sep 2017, 12:01 PM #21Most Valued Member
- 2,713
Phil (machtool) had a pile of then EDM cut from a sheet of carbide for us local scraper types. Really nice quality, same size as the Sandvik ones IIRC. I've got 3 or 4 of them.
Since he got kicked off the forum, good luck getting any though. You could try getting in touch via Practical Machinist.
PDW
30th Sep 2017, 12:53 PM #22Senior Member
- Mar 2017
- Brisbane
- 245
Thanks! Actually I was trying to obtain one because I received your email and was planning on coming along. I'll just come along on the day then. Incidentally, do you think a little Taig lathe would make a decent first scraping project? I thought I'd bring it along since it's 20kg.
I watched the Stefen Gotteswinter vids and they were very good.
@PDW I might try, thanks. It certainly seems strange how hard it is to get stuff for scraping.
Scraping looks perfect for a home shop guy for making a few surfaces flat, especially if you don't want to buy a grinder. I was checking out grinder prices and they're very expensive. An alternative if you have more time than money?
30th Sep 2017, 01:18 PM #23Senior Member
- Jul 2017
- 29
- 114
We could give it a try, are the ways hardened? I've been watching a few Russian videos of abrasive scraping using a pneumatic die grinder and a 2" cut off wheel which I'm really keen to try out. Also as to the BBQ a few people asked about having it as a sort of car boot sale/swapmeet as well for machinist/rebuilding related things as there are quite a few people with larger tooling that only own small mills/lathe and vice versa. Emma Ritson for instance had a crate of horizontal milling cutters delivered here from Sydney yesterday and I think most of these cutters dwarf her tiny machines.
If you don't mind me asking whereabouts on the east coast are you located PDW? It'd be great if we could have an expert come along and if you're not too far past byron I could come pick you up or send someone down so you can have a few beers while you're here.
1st Oct 2017, 11:39 PM #24Senior Member
- Mar 2017
- Brisbane
- 245
2nd Oct 2017, 10:53 AM #25Senior Member
- gold coast
- 303
I can only make it on Sunday 8th, at this stage.
4th Oct 2017, 11:46 AM #26Senior Member
- Jul 2017
- 29
- 114
4th Oct 2017, 07:03 PM #27Most Valued Member
- 2,713
Most of the time I live in Tasmania. Some of the time I live in Sydney and I generally spend some time in Brisbane as well, working with one of my clients. It all depends on the year, the weather and how bored I am.....
Off to the foundry tomorrow if things go to plan. I'm getting some more right angle squares and straight edges cast. Might take a new pattern with me as well if I get it done in the morning.
PDW
14th Oct 2017, 10:06 PM #28Senior Member
- Mar 2017
- Brisbane
- 245
I milled a 20x4x470 piece of mild steel to test its flexibility and others warned me on the meet up day it does indeed deform permanently (though slightly) when you bend it. A mate recommended trying some car leaf spring steel from a car yard. Sounds like a decent idea to me, depending on how much I can get it for. I don't visit wreckers often.
Granite Surface Plate S.A.
By DSEL74 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 9th Feb 2016, 01:25 PM -
Surface plate ( granite ) blue
By morrisman in forum METALWORK GENERALReplies: 14Last Post: 2nd Aug 2014, 07:23 PM -
Wanted granite surface plate
By Dave J in forum METALWORK GENERALReplies: 0Last Post: 20th Apr 2013, 06:01 PM -
SOLD: Granite surface plate grade A
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 8Last Post: 18th Jun 2012, 08:44 PM
